Originally posted by hinckc I think I'll be using it a ton, too. Having this kind of reach seems to give me lots of ideas for shots. I am certainly looking forward to the warm weather to use it more outdoors. Most of the birds were shot from my kitchen, with the scope pointed out the back window! I wonder how much, if any, the thermal currents of the heat leaving my house effect the pictures...
Actually, the two surfaces of the pane of glass (or four is storm window) produces a good deal of distortion, the more the less perpendicular are to the glass, and the higher the larger the refractive index your glass has. I've yet to test this, but I think it's more the closer you are to the glass surface.
I recently purchased a 3x eyepiece from Pete Zack to make the 300mm f/2.8 into a telescope. I clicked in all 3 of my TCs, stacking the 1.4 and 1.7 too. I started my try-out inside, 2x TC (making 1800mm), pointing at the harbor masters house about 2+ miles away from my house across the inlet to all the local bays,
eatons neck, ny - Google Maps through 1 pane of [somewhat thick] glass out the back of my house. I was [ahem] disappointed. At best focus, it was a
mess; pure blur from distortion.
I went outside, moving down to my 1.4x. Whoa, what sharpness. The building, and 5mph painted onto the side of the building was incredibly sharp. I thought the 2x, or 2x in this combo, was crap. I then tried 1.7x, then 1.4x + 1.7x (2150-ish mm !) . All were so sharp, with the big 5mph sign on the little sandbar the building is built on serving as by guide for critical focus.
So I said to myself, well, let me
try the 2x again. Bang, very sharp. So I realized, that one pane of glass I was up against and looking through, and not perpendicular against so I could point to my subject, was severely degrading the image. And the 'telescope' was of course magnifying the effect. (as it magnifies the CAs and purple fringing of my lens wide open
I didn't test, but I'm thinking had I moved back a few (or few dozen) feet from the glass, the distortion effect from the two sides of the pane of glass would have been much less, as that ratio of my distance from the glass to the glass thickness would have been negligible.
