Originally posted by 123jippo Wow really nice! Can i request focal lenght and aperture used for these pics pls? and HDR software used also...
Of course you can! I keep no secrets...
1.Short trees, tall shadows:
Exposure times : 1/125, 1/400, 1/50, 1/1000 and 1/20 sec (1.3 EV difference between each step)
Aperture : F9
Exposure bias : 0 EV
Focal length : 8.0 mm (35 mm equivalent: Unknown)
ISO speed : 400
Exposure mode : Aperture priority
Metering mode : Center weighted average
White balance : Auto
2. Aladdin's genie
Exposure times : 1/250, 1/800, 1/100, 1/2000, 1/40 (again 1.3EV steps)
Aperture : F8
Focal length : 16.0 mm (35 mm equivalent: 24.0 mm)
ISO speed : 400
3. Surhuisterveen sunset
Exposure timeS : 1/500, 1/320, 1/500, 1/125, 1/1250, 1/80 s (1 EV steps)
Aperture : F8
Exposure bias : -1 EV
Flash : No, compulsory
Focal length : 8.0 mm (35 mm equivalent: 12mm)
ISO speed : 400
4. Horizon highlight
Exposure times : 1/200, 1/500, 1/80, 1/1600, 1/30 (1 EV step)
Aperture : F7.1
Focal length : 17.0 mm (35 mm equivalent: 25.0 mm)
ISO speed : 400
Used software and method (all images initially started as PEF raws):
1. LuminanceHDR (
About ) open source and cross-platform HDR software capable of handling most any raw format in use.
Load PEF files into LuminanceHDR and let the program figure out how to align the handheld shots precisely.
Generated an OpenEXR 32-bits HDR file which was then tonemapped with two different tonemapping operators: Mantiuk06 and Fattal, each of which was saved as a 16-bit PNG file.
2. GIMP or CinePaint (
CinePaint Docs), GIMP's older and slightly aging sibling which I sometimes use for layering as it does handle 16-bits.
a)Fattal file as base layer with the Mantiuk06 file layered on top at 34%-50% transparency.
b)Layer merge
c)Levels & curves
d)Layer duplicate
e)Desaturate top layer and set layer mode to "overlay"
f)Layer merge
g)Save as (GIMP: 8-bit, CinePaint: 16-bit) TIFF
3. NeatImage (
Neat Image - best noise reduction for digital cameras and scanners), the only commercial and fully paid software package I use, mainly because of the quality of the results, their staunch linux support and their reasonable price and free update policy.
a)Analyze noise from program-selected image patch
b)Set noise-reduction preset to "Filter and sharpen"
c)Save result as 16-bit TIFF
4.ImageMagick (
ImageMagick: Convert, Edit, Or Compose Bitmap Images) through a batched workflow
Resize to 33%, set black outline and add signature
Save as JPEG
