I have a big shoot in which I've designed from the ground up. I've hired a professional model, an MUA (make-up artist), and hired on an assistant to over look style and help hold reflectors.
I had trouble with spill and control with my high-key style shoots so today I sat down and tweaked my lighting for two hours and finally have it situated and documented. Here are the results and I need tons of input to make sure the lighting looks good and under control. I notcied much fewer blown highlights and less color bleed which is a great start.
All shot with Pentax K10D, ISO 100, 1/125 shutter, f6.5-7.1 and the lenses were either the FA50mm 1.4 and the DA* 16-50mm 2.8.
First test shot DA* 16-50mm
Second test to see if the light will work lower and it does
Stretching the light forward and back to see how the light folows.
Huggies
Playing with the 50mm 1.4
Layin down...
All of these shots are RAW converted straight to JPEG then uploaded. No photoshop, no sharpening added. I think the way the light is working for these I should be good to go for the real thing. Now I need to perfect my second lighting guide for the shoot.
