Originally posted by eaglem Good detail considering I assume it being a very small moth.
Yes EM, original uncropped image. probably more than half an inch in real size at max 1:1 magnification..:
Originally posted by bluestringer Very nice capture Marcus. I've been thinking about using a monopod. Are you using it with a manual focus lens?
Yes, Dennis. Monopod or tripod for most of my macros together with flash light and diffusers. At maximum magnification of 1:1, the gear has to be steady and a little breathing will affects the sharpness too. Sometimes in prone position and the ground could be used as a support or else leaning on some trees of concrete for support, otherwise using legs and arms if possible to firm the gear when shooting..
Originally posted by tessfully Very very nice image. I often use a monopod, especially while hiking. I bought one that my regular tripod head can mount onto so I am very comfortable with it and it works great for landscape etc.. I am not sure I would get such a great macro. Wonderful shooting!!
Thanks Tess for your kind word. I am sure, without doubt that your could produce a great or better macro. Having the right set up, and when opportunity arise ie when the moth appears right infront of you within good clean background
.. In this case, the leaves does not have reflective surfaces on where the moth was located and with the diffusers, i think the lighting is nice and soft.
Originally posted by slowpez What a lovely moth. Love the green background of the leaves too.
Thank you,susan. ITs the diffuser that diffuse the light to create that soft effect. I, myself like the soft effect not having harsh white spots from flash light, on the background.
marcus
