Originally posted by eaglem If you use Photoshop CS6 it's easy to remove the dust spots using the lasso tool then going to Edit...Fill and make sure "Content Aware" is selected. Another tip you may find valuable is to increase your contrast while decreasing your brightness will help sharpen the shot and stop the over exposed look.
No, I don't own PS. I used the Object Remover in PSP X4. I also tried the Spot Remover in SilkyPix Developer Pro 4, but it's not as useful as the OR tool in PSP.
In the original I had increased the contrast and dropped the rendering brightness ("Exposure" control) in SilkyPix. In the replacement version I compressed the dynamic range in SP, dropped the rendered brightness a bit more, and pulled up the shadows a bit with SP Pro's Dodging control so it wasn't too dark.
Dan.
