MX-1 soo cool!
Lens: Sigma 17-70 2.8-4.5 non HSM Camera: pentax K-30
Posted By: i_trax, 06-01-2013, 09:38 PM
06-05-2013, 05:53 AM   #2
Nice setup. Do you use an optical slave on that flash bracket?
06-05-2013, 10:55 AM   #3
Nice case. Reminds me of my old Leica case for my '52 Leica Rangefinder 11f.
06-05-2013, 11:46 AM   #4
Moderator PEG Judges
Kerrowdown's Avatar
A good product shot, just look at that quality leather case, cameras should all come with one of those.
06-05-2013, 12:08 PM   #5
This looks awesome!
06-07-2013, 12:52 AM   #6
i_trax's Avatar
QuoteOriginally posted by Tanzer Quote
I will, have to find my old Pentax AF 200T and 280T first and purchase remote slave trigger.
in the meantime I am going to borrow newish Yongnuo from friend , hopefully it will have slave trigger build in.
06-07-2013, 12:54 AM   #7
i_trax's Avatar
QuoteOriginally posted by lesmore49 Quote
and it smells the same, pretty magic!
06-07-2013, 12:55 AM   #8
i_trax's Avatar
QuoteOriginally posted by kerrowdown Quote
thank you, well this camera should definitely come with one of those, it looks and feels so retro
06-07-2013, 12:56 AM   #9
i_trax's Avatar
QuoteOriginally posted by czhao1009 Quote
This looks awesome!
thank you, yes I love it!
06-07-2013, 03:00 PM   #10
QuoteOriginally posted by i_trax Quote
Let us know how it works! Some of us are put off by the lack of a built-in hot shoe.
I tried an external flash with an optical slave, triggered by my K-5 on-board flash, and it works great. I set the external flash to 1/16, so it could fire in rapid succession. Indeed, it fires on both the pre-flash, and the main flash. Resulting in perfectly metered exposures from the on-board flash!
But I tried this on my X-90 (predecessor to the X-5 bridge camera) and it didn't work. The time interval between the preflash and the main flash is much shorter, because the camera doesn't have to wait for the mirror to flip out of the way. My external flash, or the optical slave adaptor, couldn't keep up with the rapid sequence. So it only fires once, with the preflash.
I'd be curious to know if it works with the MX-1, since that also uses an electronic shutter.
06-08-2013, 08:01 PM   #11
Just an update to my previous post. I had been trying an old flash with a separate hotshoe-mounted optical trigger, which won't keep up with the X-90's fast preflash/flash sequence.
Today I tried again using the AF360FGZ with it's built in optical trigger in Slave 2 mode, and it turns out that it can keep up with the fast sequence. Not sure if that is because it is a newer flash, or because the optical trigger is built-in. Anyhow, I now have a solution for my X-90. You may have similar luck with the Yongnuo.
06-09-2013, 06:44 AM   #12
i_trax's Avatar
Yongnuo YN460 ( the older Mk I) is too slow and not really sensitive enough to be reliably used with MX-1 so I do not know if any optical slave trigger from e-bay would be fast enough to get my old AF200T and AF280T usable with MX-1.
might be better idea just to forget about them and get something newer like Pentax AF360, some people were using MX-1 with newish Nikon flashes successfully,
anyone with any suggestions, advice?
06-09-2013, 07:01 AM   #13
i_trax's Avatar
Yongnuo YN460 ( the optical sensor in the head, in Mk II they moved the sensor to the behind the red glassy plastic) works well as a optical slave with K-01 and with Sunpak DC-7 ( with Praktica PL nova I )
camera, photo
MX-1 First Impressions Adam Pentax Compact Cameras 70 12-18-2013 07:02 PM
PENTAX MX-1 HIGH-END DIGITAL COMPACT WINS PRESTIGIOUS 2013 DESIGN AWARD MX-1 Receives Adam Homepage & Official Pentax News 6 03-21-2013 09:58 PM
MX-1 French advert NickLarsson Pentax Compact Cameras 7 02-22-2013 10:38 AM
The Q with D mount soo cool! i_trax Pentax Q 12 06-12-2012 02:08 PM
Hello from the Soo! icarus Welcomes and Introductions 5 04-13-2008 05:05 AM
All times are GMT -7. The time now is 02:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
