Originally posted by Digitalis Depends on which OS you are using on your mac because Snow Leapoard uses gamma 2.2,m if you are using an older mac OS the gamma point is probably lower. Also which monitor is the most accurate also depends on which is the oldest between the two, as age an impact on colour accuracy because LCD displays experience colour shift.
Ha ha . I am even more confused now
Let me ask differently then. Imagine I have a dual system ( run both Win and Mac on the same computer ) - now in both I have lightroom installed and when I export an image - it is produced in both systems the same way - right ? The resulting JPG is basically the same. Now that tells me that no matter what system I am using - the resulting image is defined by the way it was processed - so if on one screen image still looks dark - I simply light it up a bit until I am happy, right ? Now when I get the same image on another screen - it looks differently - not only about the color differences ( to some extent ) but as you've mentioned - the gamma is set differently for both screens - so the image looks brighter and less contrasty than before on another screen. Now I would more likely undo some of that lighting up mentioned earlier...
Do you see my problem ? Now which screen tells the 'truth' so when I send a photo out for printing I wont get too dark gloomy print or washed out and too bright one. ?? How do I know for sure ? --manntax
EDIT: until now I was editing my photos and tried to balance between both screens - so looks like this was the right way ( according to your screen, telling that the above photos are ok - but would be be enough for prints ? ) - but my consciousness of these things tells me I should find out for sure and set both screens as accurately as possible..
