What Exactly Is A Riser Inlet Again?
Posted By: Kerrowdown, 06-03-2014, 05:31 AM
What exactly is a riser inlet again?... and should we be sitting on it?
PENTAX K20D  Photo
06-03-2014, 05:50 AM   #2
Maybe they were googling that while sitting on it?
06-03-2014, 06:02 AM   #3
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by ROBEFFY Quote
You could well be right, they certainly well involved in whatever, as they never saw me just a few feet away.
06-03-2014, 10:05 AM   #4
Tako Kichi's Avatar
It's a good job they weren't standing by that box otherwise it could have put a whole new slant on the interpretation (and made it NSFW too!)
06-03-2014, 10:19 AM   #5
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by Tako Kichi Quote
Hey, your just way to advanced for me...
06-03-2014, 10:21 AM   #6
QuoteOriginally posted by First Poster Quote
Dry riser
From Wikipedia, the free encyclopedia
Dry riser inlet found at the ground floor of flats to be used during fire fighting in Singapore
A dry riser inlet box at Park Street Car Park in Cambridge, United Kingdom.
A dry riser is a main vertical pipe intended to distribute water to multiple levels of a building or structure as a component of the fire suppression systems.
The pipe is maintained empty of water. The dry riser is the opposite of a "wet riser" or "wet standpipe" system where the pipes are kept full of water for manual or automatic fire fighting operations. Dry risers have to access fire engine within 18 m of the dry riser inlet box. Dry risers in occupied buildings have to be within a fire resistant shaft, usually one of a building's fire escape staircase enclosures.
Depending on regional nomenclature, the term "dry riser" may refer to a standpipe, intended to provide water to fire hose connections, or a vertical main pipe in an automatic dry pipe fire sprinkler system. A dry standpipe comprises a fire department connection, e.g. Storz, which is an external access point at ground level through which water can be pumped from the fire department's fire engine pump to firefighters' fire hose attachments on each floor, whereas a dry pipe fire sprinkler system is a network of pipes connected to fixed sprinklers inside a building, which are full of air until one of the sprinklers is triggered.
06-03-2014, 10:56 AM   #7
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by wildman Quote
Dry riser
Thanks, I'm better informed for that, but I'm not sure that those lassies are any the wiser.
06-03-2014, 07:39 PM   #8
Kozlok's Avatar
From the look of the photo, I think it made their pants tighter.
06-04-2014, 02:46 AM   #9
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by Kozlok Quote
Maybe it was a Wet Riser after all and shrunk things to fit.
06-04-2014, 03:27 AM   #10
That's it. They[I ]are[/I] sitting on the Riser Inlet. A "Riser" is what happens to a young man when he sees tight pants and an open blouse, and the "Inlet" is....well.....you get the picture. Two fine riser inlets here.
Regards
06-04-2014, 03:33 AM   #11
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by sam-joseph Quote
I think you and Tako Kichi need to get to together, as your both way to advanced for me.
07-01-2018, 06:47 AM   #12
Custom User Title
FozzFoster's Avatar
QuoteOriginally posted by Kerrowdown Quote
Ignorance is bliss! Seats everywhere!
07-01-2018, 06:57 AM - 1 Like   #13
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by FozzFoster Quote
Aye but seating choices are always better, when redheads are involved too.
07-01-2018, 07:04 AM   #14
Jackets on in this weather...were they foreign students...nice one Kerrowdown.
07-01-2018, 07:33 AM   #15
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by photomax7 Quote
No they were Lowlanders in "Auld Reekie"
nice one Kerrowdown
Thank you.
camera, inlet, photo, riser, riser inlet
What exactly is Professional to you? jeff knight Pentax K-3 & K-3 II 74 10-26-2013 10:42 AM
What exactly is an 'Entry Level' Camera? kbace50 Troubleshooting and Beginner Help 9 06-13-2013 05:51 PM
Mirror Flop! Just What Exactly Is It???? BirdDude007 Pentax K-5 & K-5 II 6 06-09-2012 08:26 AM
What exactly is Hyperprogram? bwDraco Troubleshooting and Beginner Help 11 10-30-2010 04:14 AM
O.K... so what EXACTLY is a "PRO' DSLR? slip Pentax DSLR Discussion 35 02-01-2007 06:21 PM
All times are GMT -7. The time now is 08:36 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
