Cross posted from the weekly challenge,which this week is "Old".
My old thing is an old woodworking plane. I worked for awhile in a factory that made reproduction pine furniture and we took care to use some period tools and sometimes used hand planes in levelling and finishing the tables. A hand plane properly sharpened leaves a much smoother surface than sanding if done right. One of the problems with this approach is the poor standards employed in making modern quality tools. You can get good stuff made in europe but most of the NA stuff is currently garbage. When smoothing tables it makes it a lot easier to get the table flat if you use a smoothing plane, a #4 1/2. It's wider than the more common #4 but the same length. As far as I can tell this is one from the last run made in North America, in 19010.
There are so many tip offs to the kind of quality that used to be common in these tools that is sadly lacking today.
The base of the plane was cast and the thrown outside to "age" for a year. It takes that long for a casting to become stable. Then they were machined flat. You can see how much it warped because the sides thickness varies as does the base. The base is perfectly flat after 100 years, if you check anything made recently, you can't even find a flat one in a lot of 100. They are machined while still warm and warp brutally. Also, notice the brass screw in the Rosewood knob and the brass fittings and rosewood handle. Both the brass and Rosewood are fittings of a bygone era. When I worked in the plant, this tool was prized by everyone, and borrowed for almost every table that went through the plant. Now it sits out in the shed in my tool box, it's got some rust and saw dust sticking to it. You can see where my hand rubbed off the sawdust last time I used it. I bought it at auction , I found it in a retiring farmer's tool box, along with another old treasure, a routing plane from the same era. I got them both for 5$ each in the late 70's. Even then they were worth 20 times that.
This one patented in 1902, the last date listed is 1910 so I'm guessing it was made then.
Beside it is a circular plane, that's was used to plane wagon wheels, it's bottom could be adjusted to conform to the diameter of the wheel. I have no idea who the maker is or where it came from, and it's missing it's handle, there was a poory made substitute handle on it when I bought it at auction, it looks better without it, and those things are darn hard to use, handle or no handle., another strange thing found in an auction lot in at the Auction Hall, 1/2 mile from my house near Perth Ontario.
And to the far right is a routing plane patented in 1907. These are my old treasures from my cabinet making days.
And the details....
Dates...
All the early Stanley planes were labelled Bailey's,, my Scottosh Grandmother's maiden name was Bailey. All your Bailey planes are belong to me. I'm not even sure if that still continues, I suspect not. You can see the 4 1/2 designation.
Brass blade height adjustment wheel... it looks like this got stuck once and someone cranked it with a pair of pliers, damaging the knurl.
Rosewood handles.
