Originally posted by alamo5000 What is 'color cast'? I seriously have no idea what that means.
Hi
Rather than me writing a lengthy essay, I refer you to Wiki:
Colour cast - Wikipedia, the free encyclopedia
I have made up three samples of your image with rather severe colour casts, green, blue and yellow. This should give you an idea. Wrong white balance causes colour casts.
Your images are all presenting with a rather heavy yellow cast, but it can be easily removed particularly if you shoot RAW. Your colours are all a bit over saturated as well, you must bear in mind that most printers can't really handle this very well.
The problem is; Your screen and printer handle colour in a different way and the message your screen passes on to the printer how to print colours is not understood by the printer unless precise instructions are established by way of a printer colour profile which will enable both screen and printer to sing from the same song book, so to say.
I have no experience in this so I don't know if laptops are good enough these days to be calibrated. Some others my be able to chime in. As the work I am doing requires accurate colour management I run a professional NEC monitor which is calibrated every 6 to eight weeks to correct subtle colour changes which can go unnoticed.
My calibrated monitor gets me into trouble in this forum from time to time though when I correct images as some can't see colours the way I see them on my screen.
Here is roughly what I would aiming for and again the very strong hot pink would probably cause a bit of grieve for the printer, I would have to experiment.
Greetings
