2 Likes  #1
Bite The Bullet
Posted By: Isbab, 09-13-2014, 03:11 PM
I use a Pentax K30. In addition to the wildlife photography I often take pictures at Metal concerts. This picture of the band BULLET was taken during their concert in February 2014 in Berlin.
Usually I use the Pentax DA 18-135 lens. But with a maximum aperture of 3.5 many concert pictures fail.
Using the Pentax DA 50mm lens would mean:
a) either shorter shutter-speeds or lower light-sensitivity (with less noise).
b) getting sharper pictures (than with a zoom lens)
c) beeing able to make more snapshots.
I hope to be the lucky winner of the lens!
PENTAX K-30  Photo
09-16-2014, 02:32 PM   #2
UncleVanya's Avatar
I have tried using a 50mm F/2 in concerts and found it to be too long with the APS sensor - essentially I wanted something wider. Generally I use my 18-55 or 18-135 but based on looking back I shoot mostly around 35mm - if you don't win you should look at the 35mm primes more than the 50's in my opinion.
09-17-2014, 03:57 AM   #3
Hi, bradshea, thanks for your post.
Maybe you are right. Of course the 35mm lens would fit better than the 50mm lens to the K30. But have you tried to get a good picture from the other end of the stage with a 35mm lens?
Usually I donīt stand right in front of the stage, so there is a loss of light and a loss of distance. I think, the 50mm lens would fit.
09-18-2014, 10:31 AM   #4
UncleVanya's Avatar
QuoteOriginally posted by Isbab Quote
The venue matters most - I was thinking small clubs honestly. In those I'm often too close with the 50mm since I get there early to get a good table! The fact is that with the ability of modern Pentax SLR's to push the ISO the medium speed zooms aren't too bad. Too bad the Sigma 18-35 f/1.8 stops at 35mm - something like with a little more range would be ideal.
07-27-2018, 04:54 AM   #5
Just the right moment!
07-27-2018, 11:00 AM   #6
Nice shot
bullet, concert, da, fast movements, lens, low light, metal band, pentax, pictures
Nature Don't bite the hand that feeds you. charliezap Post Your Photos! 21 06-23-2018 01:02 PM
Food The Bite chimpwithagun Post Your Photos! 2 03-22-2014 06:36 AM
Bit the bullet... yorik Pentax K-01 26 05-05-2013 04:44 PM
I finally bit the bullet... mr tibbs Pentax K-5 16 02-28-2013 02:18 AM
I bit the bullet.............. UncleRed Pentax K-30 & K-50 2 01-31-2013 10:33 AM
All times are GMT -7. The time now is 08:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
