Originally posted by Canada_Rockies You need to enable "Use Aperture" or words to that effect in the main menus on your camera. Then the camera will stop the lens down to your chosen aperture when you take the picture. You need to have the camera in M (manual) exposure mode, and use the Green button to set the approximate shutter speed. Depending on the lens you might have to tweak the shutter speed a bit to get perfect exposure.
I've got a K-5 and in menu C.4 option 27 I have it set to 2 which enables me to use fully manual lenses and set the exposure as you said. The extension tubes have a lever which ,when attached only to the lens (aperture set to 22), when you press it change the aperture to a greater one... Oh well, I might figure it out eventually...
