Thanks for starting this thread, and for sharing your experience and knowledge! Please forgive me if some of my questions are dumb - I'm very flash-ignorant.
Originally posted by old4570 One of the nicest stock flashes I have used is the AF-200FG that came with my K50 .. It works a treat ..
Are you suggesting using this flash for macro mounted on the camera hot shoe, or off camera? Your rigs seem to mostly have the flash mounted off-camera.
The rig you've posted above shows the sync cord connected directly to the flash. I just looked up the 200FG in the reviews section, and it doesn't appear to have a sync input.
The reviews are favourable, but if I get one, I'd like to have the flexibility to use it both on-camera and off.
Originally posted by old4570 Hot Shoe adapter : ( might want to order two just in case )
Hotshoe Flash Adapter Remote Control Receiver F Canon to Nikon Flash PC Socket | eBay
Ok, I think I follow. Is there an adapter that mounts the flash onto the swivel bracket?
Also, if you connect a flash using a PC cable, do you lose P-TTL capability?
As far as using my imagination goes, I looked through my photographic "junk box", and found an old Sunpack auto124 flash. It occurs to me that with it tilted over horizontally, it
has a very low profile, and would lend itself well to use with a diy extender/diffuser to channel the light up to the POF. But my guess is that the trigger voltage on this
thing is unsafe, and it would be expensive to get an adapter that would allow it to be safely used on-camera. But for "studio" work like photographing specimens, maybe it
could be used off-camera with one of these:
Flash Hot Shoe Adapter Remote Controller Slave Trigger for Pentax Nissin SYK 3 | eBay
Rather than having a cumbersome on-camera rig for specimen work, it might be simpler to have a "stage" setup with it's own flash/diffuser.
On a bit of a tangent, has anyone considered picking up one of the *ist models that have true TTL flash capability? Only 6M sensor, but still...
Cheers, R
