2 Likes  #1
macro
Posted By: marcusyoung, 04-04-2015, 01:37 AM
vivitar macro 105 with male to male adapter M 50 mm front.
f11, 1/80 secs flash light.
marcus
04-04-2015, 01:51 AM   #2
Markovo's Avatar
Hairy and perfect!
04-04-2015, 02:02 AM   #3
LeGuillotine's Avatar
Great ones! did You have living model?
04-04-2015, 02:40 AM   #4
HYS
Great!
04-04-2015, 05:12 AM   #5
QuoteOriginally posted by Markovo Quote
Hairy and perfect!
QuoteOriginally posted by LeGuillotine Quote
QuoteOriginally posted by HYS Quote
Great!
thanks. This shot was taken with a few images in control envorinment and stacked, using helicon. Its not possible to have
DOF across the plane of the fly in sharp focus in a single shot even stopping down to the smallest aperture.
marcus
04-04-2015, 10:01 AM   #6
a disgusting amount of detail. Well done! Great pictures!
04-05-2015, 08:24 AM   #7
QuoteOriginally posted by Volker76 Quote
thanks,
One more here about 6 to 8 images stacked.
marcus
04-10-2015, 09:41 AM   #8
voigtlander macro wilth reverse adapter with 50 mm infront. uncrop.
marcus
04-11-2015, 03:02 AM   #9
Nass's Avatar
Great stuff! You are using a topdown diffuser?
04-11-2015, 09:02 AM   #10
QuoteOriginally posted by Nass Quote
Flash light used was AF 200 fg attached to hotshoe of camera. I used Styrofoam plate to the far end of the lens tied with a rubber band to hold it in place for diffusion. The working distance is very near, probably an inch and almost impossible to capture in horinzontal position. Most shot were taken in an angle 45 degrees downward with voigtlander macro and 50 mm infront reversed. The same when I used an A200 macro with 50mm infront reversed but will have a much higher magnification.
I have read some of your notes on preparation but its a long long articles to read. maybe to me only, still thanks on your effort on the write out.
Bought helicon and zerene as well and serene is just too slow. But if I were to put into print, I may do it on zerene to choose the background from the stacks.
Those latter 2 shots were without retouching.
Also have some orchids stacked with 645Z and I have very good results.
Will post some orchids some other time.
marcus
04-12-2015, 06:21 AM   #11
brought down to eye level and captured this. Uncrop
marcus
04-16-2015, 08:55 AM   #12
marcus
04-20-2015, 07:00 AM   #13
marcus
04-22-2015, 06:56 AM   #14
voigtlander macro 125 reverse ring 50 mm infront.
marcus
adapter, flash, flickr, housefly, light, macro, male adapter, mm, secs, vivitar, vivitar 105
Macro Macro book suggestions csa Photographic Technique 13 02-17-2015 02:37 PM
Macro Subtle Macro Kerrowdown Post Your Photos! 6 07-07-2014 01:04 PM
macro extention tubes Arimel Troubleshooting and Beginner Help 19 04-18-2013 01:15 PM
All times are GMT -7. The time now is 01:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
