Thanks Kris!
I set the camera to ISO 800, Tv 1/125s. I also used center weight metering and linked AF ponts to AE. I then took the shots like I normally would. The 1/125s shutter was quick enough to freeze most faces, and the venue's lighting on the dancers was enough to expose detail in the faces and such. As you can see, the background and foreground (heads) were underexposed out of some of the photos though. I also used a 1B warming filter on the lens
Also, they didn't come off the camera that way. I had to do a lot of PS work to get the skin tones to pop out of the photos. Mainly an 80 cooling filter at 10% to bring the tones down, and some heavy smart sharpening. Then I bumped up the midtones in curves by about 3-5% to make skin glow.
If you look at the photos real big, you can tell that the detail is a little washed away by noise. For example, here's one of them at 830x1024.
Anyway I hope this was helpful.
Thanks,
