More from Milan
Lens: See description Camera: K-5 II Photo Location: Milan and Lake Como, Italy
Posted By: wkraus, 06-14-2015, 09:33 AM
As mentioned before here: https://www.pentaxforums.com/forums/12-post-your-photos/297575-black-white-tr...#ixzz3d2yNrxDv, I did a short trip to Milan and Lake Como with my K-5 II and a set of Takumars (28mm, 50mm and 135mm) complemented by the DA 21mm and 70mm Limited lenses. While the earlier thread was all B&W, here are some shots in colour, but still in square format. This time only the S-M-C Takumar 135mm is participating, with the rest from the Limited lenses.
DA 21mm Limited
DA 21mm Limited
DA 70mm Limited
DA 21mm Limited
Super-Multi-Coated Takumar 3.5/135mm
DA 21mm Limited
DA 21mm Limited
DA 21mm Limited
06-14-2015, 12:09 PM   #2
PEG Moderator
Kerrowdown's Avatar
An interesting city that's still on my list.
I always imagined it to be far busier or have you just shown the quite bits.
06-17-2015, 11:42 PM   #3
mcgregni's Avatar
That's a good set of photos, nice tight framings and with a focal point. I especially appreciate the well controlled exposures (ie not overexposed, which would be so easy to do ).
06-18-2015, 06:21 AM   #4
QuoteOriginally posted by mcgregni Quote
Thank you for the kind words! Although I mostly shoot in manual mode with spot metering, when using the Takumars I preferred AV mode and centre-averaged metering, much of the time with a -1/2 correction and low ISO. If needed I raised the exposure during raw processing.
06-19-2015, 12:25 PM   #5
mcgregni's Avatar
That's a sensible approach in these conditions for sure .....each scene has a pre-dominant mid / low mid toned basis with small patches of brighter highlight.
« Scottish Rule | MK »
135mm, 21mm, 70mm, camera, da, lenses, milan, photo, takumar
Greetings from Milan Bellachioma Welcomes and Introductions 6 02-08-2015 02:31 PM
Hello from Milan (Italy) ;) franco_dc Welcomes and Introductions 4 08-23-2014 01:57 PM
Hello from Milan, Italy. Bravolima Welcomes and Introductions 3 05-20-2014 12:40 PM
Streets Streets shots from Milan AKum8 Post Your Photos! 10 05-06-2013 02:04 PM
Hello from Milan, IN home of the Movie "Hoosiers" N9HEH Welcomes and Introductions 2 12-31-2007 11:20 AM
All times are GMT -7. The time now is 04:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
