1 Like  #1
Tonights moon with K-3
Lens: 1200mm telescope Camera: K-3 Photo Location: Belfast ISO: 100 Shutter Speed: 1/250s Aperture: F7.1
Posted By: wahee, 12-22-2015, 01:06 PM
Tonight's moon shot with a K-3 attached to a Meade 5000 APO F7.5 refractor telescope using an adapter.
full res here
http://www.mindburner.co.uk/astroimages/images/lunar_pentax_1_JPG.jpg
12-22-2015, 01:14 PM   #2
Pete_XL's Avatar
Wow!!!!!!👍👍👍
Is it a single shot or stacked?
12-22-2015, 01:55 PM   #3
wahee's Avatar
QuoteOriginally posted by Pete_XL Quote
Wow!!!!!!������
hi yea I should have said. It's a single exposure. I don't like stacking such a bright object as it can usually be done in one shot. Stacking can introduce some anomalies. Good for deep space stuff though.
I had to take over 50 exposures before I found one that was right. Wind, turbulence and camera settings all added to the session. I used a remote control on the shutter to minimise shake
I should have switched off Noise Reduction but it hasn't hammered the image too much I hope
12-22-2015, 01:59 PM   #4
slowpez's Avatar
Brilliant.
12-22-2015, 02:04 PM   #5
wahee's Avatar
QuoteOriginally posted by slowpez Quote
Brilliant.
thanks very much
12-22-2015, 08:30 PM   #6
vievetrick's Avatar
Awesome
12-22-2015, 09:26 PM   #7
mattb123's Avatar
I don't usually like shots that include only the moon and no landscape but I'll make an exception for this. Nice detail in there!
12-22-2015, 11:36 PM   #8
Pete_XL's Avatar
QuoteOriginally posted by wahee Quote
For a single shot it's even better
Atmospheric turbulence and vibrations of any kind are really a problem at 2000 mm. I once adapted a 600 mm Sigma mirror lens on a 2x teleconverter to an Olympus OM-D (crop factor 2x) and used it's internal lossless 2x-magnification function in Full HD movie mode. That gave 4800 mm!!! for a moon panorama. I filmed the moon in HD-Mode 1920x1080. The single frames (1 Minute = 1800 frames) were mostly really bad. But I put everything into a free software called Autostakkert and I was stunned by the result.
Greetings, Pete
12-23-2015, 10:31 AM   #9
wahee's Avatar
QuoteOriginally posted by mattb123 Quote
Thanks a lot. I wanted to push the K3 sensor and improve on what I was doing with my old Canon 1100d. Hopefully I'll get a chance to shoot Orion and a few others soon
12-23-2015, 10:39 AM   #10
wahee's Avatar
Greetings, Pete
wow 4800mm, That's something. Would love to see the panorama if you have it. I did use a barlow lens, effectively doubling the magnification but found the result was actually worse, probably due to local seeing conditions. I will check out the stacking software you mentioned. I did try Registax but my PC ground to a halt while trying to process the images. I wish the K-3 had the ISO 80 mode as this might give even better resolution. I just got a Pentax 300mm prime so will try this next time. I also have a rather nice Canon 200mm f2.8 which is great and I can bodge it to the K-3 for fully manual shots.
Attached is another moon shot from a while ago.
PENTAX K-3  Photo
12-23-2015, 12:35 PM   #11
Pete_XL's Avatar
Great Image!
Here is one of the 8 single images I derived from eight clips of one minute each (ca. 1800 frames der clip, choosed best 50% by help of the software):
...and her is the pano stiched with Microsoft ICE:
It was my first and only try with that mirror lens which was really smooth and of very poor contrast. The 2x third party converter I used is a crap, must be out of the sixties. But the whole "construction" cam, TC and lens was only about 30 cm long!!!😀😀😀
The single photos you would have thrown away. But the result is not too bad. As I said, it was a test of the software and the general technique of filming instead of photographing and for this it was very OK I think.
12-23-2015, 12:57 PM   #12
wahee's Avatar
that's a really nice close up. Very well done. Very sharp. The lens you used must be pretty decent, especially with regard to CA. Focus is really nailed. The stacking result is really good. I like the fact that it can 'save' a potentially ruined night of imaging. The shots on this forum are amazing and show what folk are doing with camera lenses, better than many a dedicated telescope. I'm hoping the low noise of the K-3 will be good for imaging large areas of the night sky. I have a stepdown ring for the front so that I can effectively step down my lens a bit to remove star spikes.
12-23-2015, 05:11 PM   #13
Ex Finn.'s Avatar
Wow, those are crispy wahee, well done and thanks for sharing.
12-23-2015, 06:55 PM   #14
jpzk's Avatar
Unreal !!
I can see the US flag there !
That is quite a sight this (these) image(s).
I haven't yet seen something that close and detailed on this forum.
Superb shots!
12-23-2015, 08:12 PM   #15
Wow - very clear and sharp...great pic.....
camera, moon, photo, tonights moon
K-3 resolution with 4:3 aspect ratio? panonski Pentax DSLR Discussion 3 09-28-2015 01:25 PM
Night Moon with K-3 and 127mm telescope wahee Post Your Photos! 7 10-12-2014 06:35 AM
Nature Tonights Supermoon Heinrich Lohmann Post Your Photos! 14 08-16-2014 01:01 PM
Night Tonights Moon.. drewski37 Pentax K-3 Photo Contest 0 05-07-2014 09:00 PM
Nature Tonights Super Moon kkoether Post Your Photos! 4 05-05-2012 09:12 PM
All times are GMT -7. The time now is 03:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
