Fly Photography
Posted By: sjovolde, 09-25-2016, 08:49 PM
I also posted these in the macro group, I'm sorry if you follow both. Any tips photography wise or editing would be appreciated.
09-25-2016, 08:57 PM   #2
Photo Forum Moderator
photolady95's Avatar
Do you know what the settings were you used? If you do, it would help us help you. What f stop, any specific lighting helps. Actually it's better if you upload photos with EXIF intact. For example, smaller apertures f8 and above give more DOF and make for things such as better detail captured.
09-25-2016, 09:12 PM   #3
My apologies, i thought the exif info would show up. All are take with K3 and DFA 50 mm macro. A speed light is setup to the right running TTL metering. The camera is set at ISO 100, 180th shutter speed to get a black back ground.
Picture #1 F32,no reflectors.
Picture #2 F2.8 with a rubbermaid tub lid acting as a reflector on the left side. I know, kind of hokey, but it works. I was going for very little depth of field but still being able to light the left side as well.
Picture #3, the bait fish streamer. F22 with the same reflector set up.
If you would like a picture of the setup i could rig my my Kx and take a picture.
Evan
09-25-2016, 09:30 PM   #4
QuoteOriginally posted by sjovolde Quote
Picture #3, the bait fish streamer. F22 with the same reflector set up. If you would like a picture of the setup i could rig my my Kx and take a picture. Evan
Well, if that's the effect you were looking for, I'd say you did a good job. I noticed your photos are hosted via flickr, if you use BBcode and copy and past the code here it will keep the EXIF intact and others will be able to click on the image to see a larger photo and more details in said photo plus be able to see which settings you used. These are kind of small and hard to tell if the f32 caused diffraction or not.
I'm curious how the Rubbermaid lid can reflect. Most are a dull color and I'd think that would detract rather than reflect.
09-26-2016, 09:50 AM   #5
I've found that using a rod inserted into a cork or a clip attached to a rod elevate the fly enough so that you won't have the distraction of the lid? in your first image
a couple of guys I've seen just hot glue the hook to a dowel or rod
you can edit the support out in post and the fly appears suspended
nice flies
is the head of your mouse (it is a mouse?) craft foam as well?
09-26-2016, 11:33 AM   #6
CCC
Thanks for the ideas.
It is a mouse. The head is made out of a foam popper head and then coloured with sharpie markers.
Evan
09-26-2016, 12:56 PM   #7
I used cut up boxes, etc for backdrop support/lightboxes
ultimately I ran across a foldio on clearance/sale
it comes with led lights but I've used a pair of ikea lamps for a while now
they are quite small, bright and inexpensive
your mouse appears to use zonker strips
doesn't that get fairly heavy when wet?
btw...sharpies are amazing aren't they?
apparently i'm not firing on all cylinders...
for props could use your reel, a branch, i used an old tobacco tin once, a pocket knife...i'm sure you get it
I have a picture somewhere where the person used heavy mono hold the fly for a horizontal shot
09-27-2016, 06:01 AM   #8
CCC
Thanks for the other ideas. Another background I use are spare pieces of tile from my kitchen floor. It's a man made tile, but looks like limestone. The fly looks like it's sitting on rock.
As far as the mouse, it's tied out of rabbit zonkers, but I use the majic tool to cut the hide of and spin the hair in a dubbing loop. I haven't had a chance to cast it but I hope it's not too bad. If it is I'll use my 8wt.
09-27-2016, 08:04 AM   #9
I also use 12x12 floor tiles...samples actually from a home center
sometimes I thoroughly wet them and add a couple of stones, it's a nice effect
I ran across a fellow in Wisconsin who set a "diorama" with tile, stones and driftwood
then epoxied (bar finish) the whole thing
it did look like a stream bottom
he shot his custom lures mounted on it
the reason i'd asked about the fly is I tie a similar one...more a gurgler/mouse( I suspect yours will act more like slider) for largemouth (no trout within a long day's drive)
the zonkers become almost alive but soak up a lot of water and a day slinging an 8wt is a long day
so I switched to craft fur dubbing loops and use either silicone cord or leather lace for the tails
using a size 6 hook I can get by with a 5wt if I work at it
6wt is about perfect
i'll quit bothering you
thanks for the info
craig
photography
Macro New at Macro Photography Jedi_Strings Post Your Photos! 6 09-20-2015 06:33 PM
Nature fly Robin fly GeorgeSnow Post Your Photos! 2 05-29-2015 03:39 PM
Amazing Photography Tricks: How to Make Someone Levitate or Fly hockmasm Photographic Technique 3 12-10-2010 07:58 AM
Macro Spider Catches Fly - I'm Officially Hooked on Macro Photography! iocchelli Post Your Photos! 4 08-02-2010 12:33 PM
Macro Bee/Fly/Ant, Venus Fly trap 100mm vs 50mm angelo9978 Post Your Photos! 3 03-18-2010 09:33 PM
All times are GMT -7. The time now is 04:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
