Milkyway, first time with Sammy 14mm f2.8
Lens: Samyang 14mm f2.8 Camera: Pentax K-3 ii Photo Location: Sweden
Posted By: pentaphil, 10-07-2016, 12:34 AM
Hi everyone,
this was on of my first attempts in shooting the Milkyway. I used a Samyang 14mm f2.8. Lens was brand new and never used before. So I had to learn how to handle the lens
Hope you like it. Maybe you can give me some tipps how to do better
It was quiet hard to focus at night. I read that some people fix the focusring with tape. But I was shooting also in the day, so this was not a good option for me
10-07-2016, 03:09 PM   #2
Aaron28's Avatar
nice decent work
10-07-2016, 06:16 PM   #3
To focus at night, find a bright star point lens at it, go into live view then magnify live view as far as it will go, then focus until the star is as small as possible. That trick works, and I learned it here on the forums. Definitely use the astrotracer. A 2 minute exposure works very well at 400-640 ISO. Use a cable or IR remote, but an electronic timer cable remote is the best way to go, and set it to a 3s delay. If you notice the stars trailing at 2 min, then cut the time of the exposure back by 5-10s each adjustment until you have minimal trailing. You will have to bump up the ISO but usually never more than 800 in bulb using the astrotracer.
10-09-2016, 11:45 AM   #4
Greenneck's Avatar
QuoteOriginally posted by Auzzie-Phoenix Quote
2 minutes is going to trail with any lens... For a 14mm they can even trail a tiny bit at 30 seconds.
Best bet to focus at infinity during the day then either learn where that spot is on your reference scale, or make some sort of small mark on it you can reference at night, and research hyper focus distance Hyperfocus table if you need your foreground sharp as well
10-09-2016, 04:37 PM   #5
QuoteOriginally posted by Greenneck Quote
2 minutes using a UWA with astrotracer function enabled is quite feasible. The edges will trail, but the center will be sharp. You will have foreground blur though. All depends on how you want to do the shot.
08-02-2018, 10:07 AM   #6
QuoteOriginally posted by pentaphil Quote
Hi everyone,
Gorgeous!
14mm, camera, f2.8, lens, milkyway, photo
Difficulty with Rokinon 14mm f2.8 on K-1 eliphas Pentax K-1 5 08-10-2016 06:46 AM
Night First milkyway! Dreams come true tengo Post Your Photos! 11 07-11-2015 05:46 PM
Help with Rokinnon 14mm F2.8 agatchell Troubleshooting and Beginner Help 14 07-10-2015 01:08 PM
Vivitar 14mm f2.8? Same as Samyang/Rokinon/Bower 14mm f2.8? buliwyf Pentax SLR Lens Discussion 18 05-14-2015 08:18 PM
Help: Long time lurker first time poster, tamrom 17-50 2.8 vs sigma f2.8 for low ligh monkclothing Welcomes and Introductions 4 12-12-2012 02:41 PM
All times are GMT -7. The time now is 01:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
