K-3 II (Pixel Shift vs.HDR vs. Flash (Shanny SN600FGZ)
Lens: Pentax 50MM Prime 1.8 Camera: K-3 II
Posted By: Lmcfarrin, 02-28-2017, 08:38 AM
K-3 II (Pixel Shift vs. HDR vs. Flash (Shanny SN600FGZ)
IMG4035 = Taken with Shanny SN600FGZ Flash | F22, ISO 1600, 1" shutter (tripod)
IMG4041 = HDR | F22, ISO 1250, 13" shutter (tripod)
IMG4042 = Pixel Shift | F22, ISO 1000, 13" shutter (tripod)
---------- Post added 02-28-17 at 09:44 AM ----------
Additional:
The HDR photo was taken while using the Shanny SN600FGZ flash
PENTAX K-3 II  Photo
PENTAX K-3 II  Photo
PENTAX K-3 II  Photo
02-28-2017, 09:12 AM   #2
NS_Sailor's Avatar
The HDR and the Pixel Shift shots seem to have brighter back grounds that the flash only shot with little difference between the two.
I also noticed a blue tinge distortion of the color on the wall on the left side of the picture, possibly caused by the blue indicator light on the item plugged in behind the lamp. The indicator light also seems to be much brighter and more prominent in the 2nd two photos
02-28-2017, 09:48 AM   #3
Lmcfarrin's Avatar
Thank you for your response/ critique which will aid my improvement. I apologize for not specifying the intent of my post.
... as is lighting conditions, straight out of camera with no tweaking for perfect exposure or composition. Hopefully the post provides examples for those who are considering or using the K-3II, 50mm 1.8, Shanny flash, and the use of hdr and pixel shift modes.
02-28-2017, 12:19 PM   #4
NS_Sailor's Avatar
It's possible the indicator light may have altered how the camera processed the HDR and Pixel shift shots. If you were to retake the shots again with the same settings and the blue indicator light removed will give a better example of the effects.
02-28-2017, 02:19 PM   #5
hdr and flash
I'm confused. If the hdr shot also used the flash, what happened to the shadow?
02-28-2017, 05:05 PM   #6
Lmcfarrin's Avatar
The hdr shot with flash has a 13 second exposure. The flash fired at the beginning of each bracketed/hdr shot, not at the end when the shutter was closing.
camera, f22, flash, hdr, iso, k-3 ii, pentax 50 mm prime 1.8, photo, pixel, pixel shift, shanny flash, shift, shutter, tripod, vs
Shanny SN600FGZ P-TTL HSS Flash for $120? beholder3 Flashes, Lighting, and Studio 132 03-09-2019 03:05 AM
Questions re: K-3 II pixel shift and Astrotracer gazelle01 Pentax K-3 102 03-06-2017 06:23 PM
K-3 ii Pixel shift of stars / night sky Conqueror Pentax DSLR Discussion 33 07-10-2015 03:16 PM
K-3 II Pixel shift for Macro? Omestes Pentax K-3 6 06-12-2015 08:13 PM
K-3 II pixel shift resized. Wow factor. JimmyDranox Pentax K-3 21 04-25-2015 09:37 AM
All times are GMT -7. The time now is 01:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
