My first real picture on the newly acquired used K-3
Lens: Asahi SMC Takumar 50mm F/1.4 Camera: Pentax K-3 Photo Location: My Garage ISO: 100 Shutter Speed: 1/180s Aperture: F16
Posted By: JohannSMac, 08-05-2017, 09:17 PM
This isn't all that artistic but my first real capture using the K-3 and an adapted SMC Takumar 50mm F/1.4 lens. Just got the camera today and finally got around to getting it up and running. A rather inglorious capture of a cigar I was smoking in my garage. I got the focus with the aperture wide open then stopped it down all the way to F/16 and used the flash on the camera at about 1/2 power. I'm amazed at the sharpness and detail as well as the color and tonal rendition using this lens! I currently have this lens and the SMC Takumar 135mm F/3.5. Looking to add the SMC Takumar 28mm F/2 or F/2.8 and a K-mount telephoto lens for birding.
PENTAX K-3  Photo
08-06-2017, 01:50 AM - 1 Like   #2
twilhelm's Avatar
Nice shot with great colors. I've recently purchased my K3 used also, and it's a great camera. And that's a good cigar you were enjoying!
08-06-2017, 07:11 PM   #3
Thanks! Yes, I enjoyed the cigar very much.
08-06-2017, 09:59 PM - 1 Like   #4
Des
Des's Avatar
K-3 is an excellent camera. Don't be surprised if there is a bit of a learning curve - well there was for me from a K-30. I found it helpful to read the PF review of the camera in detail, and of course the manual. And Yvon Bourques's ebook is very informative too.
QuoteOriginally posted by JohannSMac Quote
Looking to add ... a K-mount telephoto lens for birding.
Work out your criteria first. Here are some ideas in autofocus (AF) lenses:
1. Zoom, money and weight no object, very high IQ, WR, quiet AF: DFA 150-450. (And for more reach in good light, add a DA 1.4x tele-converter (TC).)
2. Zoom, substantial budget, prefer mid-weight, prepared to wait and look for it, don't need WR, screw-drive AF is OK: Sigma 100-300 f4 + TC
3. Zoom, want a lot of reach, money limited, but don't mind the weight, don't need WR, screw-drive AF is OK: Bigma, or Little Bigma (ie Sigma 50-500 and 150-500, respectively).
4. Zoom, light weight matters more than long reach, reasonable amount available to spend, WR, quiet AF: DA 55-300 PLM
5. Zoom, light weight matters more than long reach, limited amount available to spend, WR, screw-drive AF is OK: DA 55-300 screw-driven WR
6. Zoom, light weight matters more than long reach, tight budget, don't need WR, don't mind screw-drive AF: DA or DA-L 55-300 screw-driven non-WR
7. Prime, max reach, unlimited budget: DA 560 or Sigma 500
8. Prime, decent reach, substantial budget, WR, excellent IQ: DA*300 f4 + DA 1.4 TC
9. Prime, decent reach, reasonable budget, excellent IQ, not too heavy, don't need WR, don't mind screw-drive AF: F* or FA*300 f4.5 + third party 1.4 TC
10. Prime, decent reach, reasonable budget, very good IQ, don't need WR, don't mind screw-drive AF, don't want to use a TC, prepared to wait and look: Sigma 400mm f5.6 tele macro
5 & 9 are the value options at present IMO. You could get both for about a grand. (That would barely get you the hood and tripod foot of the DFA zoom. ;-) )
08-06-2017, 10:32 PM   #5
Thanks for the info. Please, what does WR stand for?
08-06-2017, 11:35 PM - 1 Like   #6
Des
Des's Avatar
Weather resistant. There are seals at various points around the lens that will help stop water getting into the lens. When you use a WR lens with a WR body (such as the K-3), it will help protect the camera from water ingress too. The weather resistance isn't perfect - I wouldn't try dropping the camera and lens into a river, although people have done so, with mixed results. But WR lets you use the camera and lens in the rain with reasonable confidence. It's still prudent to minimize exposure to moisture, and to wipe down the camera and lens as soon as possible if they get wet.
Some Pentax lenses (e.g. the big, heavy and expensive DA 560mm f5.6) are designated "AW" for all-weather - they have a higher grade of weather-resistance.
Weather-resistance was only introduced to Pentax lenses after they started making lenses specifically for digital cameras (the DA and DFA lens series), and after they started making camera bodies that supported weather-resistance. (So none of the Takumars or M42 lenses, or lenses in the Pentax K, M, A, F or FA series of lenses, was WR.) All the Pentax DFA zoom lenses are WR or AW. The current version of the wonderful DFA 100mm f2.8 macro lens is WR, but earlier DFA primes are not. All the DA* lenses are WR, and some of the plain DA lenses too. If you look at the lists in the Pentax Forums lens reviews (Pentax Lenses - Pentax Lens Reviews & Lens Database), it will tell you which lenses are WR.
As far as I know, none of the third-party lenses available in Pentax K-mount has weather-resistance.
The popular Pentax DA 55-300 zoom comes in four variations. Three use the same optical formula, and screw-drive autofocus. The last of those three has the WR designation. It is still available new from some suppliers, although I think it is being discontinued. The fourth model is a completely new design, with an in-lens Pulse Lens Motor (PLM) autofocus system which is fast and quiet. The PLM version is also WR. It also retracts so it is smaller for carrying when not in use. The PLM is a nice lens, but the previous models (whether new or used) are good value if you want to save some money - optically they stack up well against the PLM lens.
Incidentally, the PLM lens has an electric aperture control system, which will only work on the K-3 if the latest firmware (version 1.30) has been installed. Don't worry if it hasn't - the firmware update is free and is simple to install: http://www.ricoh-imaging.co.jp/english/support/digital/k3_s.html
08-07-2017, 12:07 PM   #7
Well duh! Should have figured that one out - pretty obvious. Thanks!
camera, cigar, k-3, lens, photo, smc, smc takumar 50mm f/1.4, takumar
Newly acquired KX conniption Pentax Film SLR Discussion 12 05-06-2017 06:26 AM
Do you put a newly acquired lens through a standard set of tests? MSL Pentax SLR Lens Discussion 19 03-26-2012 02:22 PM
My newly acquired camera! LSPhotography Non-Pentax Cameras: Canon, Nikon, etc. 4 11-17-2010 05:07 PM
Newly acquired DA 21 mm LTD : obligatory first shot! bdery Pentax SLR Lens Discussion 18 04-23-2010 05:27 AM
Misc Some Shots Taken With My Newly Acquired FA50 1.4 Christopher M.W.T Post Your Photos! 9 12-27-2009 06:01 AM
All times are GMT -7. The time now is 12:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
