I realized I didn't share my snowflake images from last winter. If you like the first one, I may post one or two more in separate posts, to get that K1 giveaway post count up a bit.
Really hope I'm not working so much at the end of the month this time so I can participate in the raffle portion! It would be fitting to win a K1 this month, seeing as this is the month, 3 years ago, I upgraded from my K20D to the K3II.
Anyway, about the image:
I believe it is 11 or so focus slices merged in Affinity Photo. Some minor pre-development done in LR first, and more minor adjustments after, but this is about as SOOC as a focus merge can get.
Lens was the Pentax 50mm f2.8 Macro (@f8) with either 68 or 72mm of extension tubes behind it. The numbers are worn off but they're older Kenko auto extension tubes and I used all three. Allows me to focus real close on these little guys with the 50mm Macro and fill a very large portion of the frame.
I also built my own focus rail to use for this, so I could move my camera back and forth on the tripod with ease. I wasn't about to spend $650 US on a focus rail when I could build one for $40 cdn of parts that performs just as well.
I need to figure out how to light these little guys. I did some experimenting but it all failed spectacularly; there's a very narrow angle of light that you need in order to show any detail, otherwise they just look transparent. This shot and all the others are done with natural overcast light.
