4 Likes  #1
Turf on the roof
Lens: DA 55-300mm ED Camera: K-70 Photo Location: Norway
Posted By: Janse, 07-31-2019, 01:30 PM
Yesterday we got the turf on our cabin roof. Hard work.
PENTAX K-70  Photo
PENTAX K-70  Photo
07-31-2019, 03:09 PM   #2
PJ1
PJ1's Avatar
Interesting operation, Janse. I can't quite relate to turf on the roof.
07-31-2019, 04:17 PM   #3
MarkJerling's Avatar
QuoteOriginally posted by Janse Quote
I'm impressed. What's under the turf? (Can you describe the roof construction and waterproofing?)
07-31-2019, 04:25 PM - 4 Likes   #4
eaglem's Avatar
How do you get the Lawnmower up there?
07-31-2019, 04:28 PM   #5
Thank you for commenting PJ1. Turf on the roofs is a very old Norwegian tradition, have may be been used from 500 B.C. The most important thing about a such roof is the waterproof layer under the turf consisting of several layers of birch bark. The lifetime of that kind of roof was about 60-80 years. Nowadays we use a special kind of plastic instead of birch bark. The mission of the turf was to keep the bark in place and also functioned as inulation. Of course the construction must withstand the weight from the turf (up to 300 kg pr. square meter together with pressure from the snow layer in the winter. :-)
07-31-2019, 06:41 PM   #6
What's the "special kind of plastic"s brand name?
07-31-2019, 07:36 PM   #7
DW58's Avatar
Sprinkler or drip irrigation?
07-31-2019, 07:46 PM - 1 Like   #8
Larrymc's Avatar
QuoteOriginally posted by eaglem Quote
Drone of course
08-01-2019, 01:27 AM   #9
QuoteOriginally posted by MarkJerling Quote
Thank you. Starting with the roof beams (rafters?), above this a wind barrier made of a special canvas which is waterproof but allows water vapor diffusion. Then comes a wooden roof, often wood fibre boards. Above this a bituben - based type of underlay. After this the special plastic. Well known products here in Norway are: Platon Xtra Torvtak and Icopal Fonda Torvtaksplate. I was using the last one. Skråtak: Platon Xtra Torvtak
Fonda Torvtaksplate | Fuktsperre laget for torvtak | Icopal
---------- Post added 08-01-19 at 01:35 AM ----------
QuoteOriginally posted by DW58 Quote
Now I use sprinkler irrigation but later I will install drip irrigation I think. ( Normally we get so much rain that irrigation isn't necessary) :-)
08-01-2019, 01:40 AM   #10
Nice! I like it!
08-01-2019, 01:41 AM   #11
Once a year the grass ought to be cut, not too short (10cm). I think I will use a chythe. :-)
---------- Post added 08-01-19 at 01:42 AM ----------
QuoteOriginally posted by Larrymc Quote
Drone of course
Haven't got one yet. :-)
08-01-2019, 10:05 PM   #12
mroeder75's Avatar
I think sod roofs were common when Scandanavians settled Minnesota, and less common, but known here in Eastern and Northeastern Iowa, where birch trees can be found. Here is sketch showing an example on a one room school house in Iowa, circa 1900, from Iowa Public Television. Sod Roofed One Room Log School House | IPTV
Thank you for explaining how this works. I never understood it. And yet, I would still like to know, do you spray for weeds? Do you remove trees from the roof? It seems like there would be more maintenance than the typical asphalt shingling we have here in the U.S.A.
08-02-2019, 07:20 PM - 1 Like   #13
Sailor's Avatar
Hey Janse, how do they hoist a lawnmower up there? It would take real courage to tackle that roof with a riding lawn mower!!
Your shot reminds me of a song from the past.
Jer
08-04-2019, 12:49 AM   #14
PEG Moderator
Kerrowdown's Avatar
Turf on the roof
Not sure that my ride on can handle a 45°pitch...
08-06-2019, 12:50 PM   #15
QuoteOriginally posted by mroeder75 Quote
Thank you so much for commenting mroeder75. More than 800 000 Norwegian emigrated to mainly Wisconsin, Minnesota, Iowa and North-Dakota and I'm sure many had buildining with sod roofs. A lot of Norwegian cabins also have asphalt shingling on the roof. I agree a turf roof needs much more maintenance. (If you like to keep it nice). I think I will remove trees and high weeds mechanically instead of using herbicides. :-)
---------- Post added 08-06-19 at 12:56 PM ----------
QuoteOriginally posted by Sailor Quote
Jer
the drifters - up on the roof - YouTube
A riding lawnmower is not a option for me Jer, I have to find another way. Thanks a lot for the song. :-)
---------- Post added 08-06-19 at 12:59 PM ----------
QuoteOriginally posted by Kerrowdown Quote
My roof angle is 30 degrees so I suppose you could handle that? :-)
asphalt, camera, drip, iowa, irrigation, jer, lawnmower, lot, photo, pm, post, roof, song, sprinkler, trees, turf, xtra
Landscape Bank of Turf mahanpots Post Your Photos! 3 11-15-2017 04:02 AM
Is Canon invading Pentax's turf? Edgar_in_Indy Photographic Industry and Professionals 27 03-31-2013 01:03 AM
Landscape Soft Turf Jimbo Post Your Photos! 20 10-04-2012 11:12 AM
Mockingbird Defends His Turf cdurfor Monthly Photo Contests 5 03-08-2011 11:48 AM
Nature turf wars eric59 Post Your Photos! 2 09-14-2010 05:32 PM
All times are GMT -7. The time now is 06:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
