Originally posted by Reality_Check Great advice. Thank you for taking the time to write out the explanation! I've been wondering about wireless flash triggers - I'll have to give Cactus a look. I recently found a post for the Pentax AF 400T flash (which looks to be a handheld wand, or gun as you refer to it) - is that something that could be used on a K-1 & triggered with the Cactus wireless flash controller? Or am I barking up the wrong tree? I did just acquire a used Pentax 540 and still have a couple of older flashes that I could try to use for this setup, but that 400 pricepoint looks hard to beat (less than $40 - untested, though).
Cheers!
I have an old Pentax 540 fgz and an old Pentax 360 fgz. Both have wireless capability so you can use one as the master (on the K1's hot shoe) and one as the slave wirelessly. I also have three Cactus V6 wireless controllers (one is used as the master/transmitter, sitting on the camera's hot shoe, and can control up to 4 flashes (counting one on top of the master/transmitter - the other Cactus V6s are set as receivers and you put the flash guns (you can use many TTL flash guns from many different manufacturers - see:
Cactus Wireless Flash Transceiver V6 | CACTUS for a list) on top of the receivers). I also have one Cactus RF60x flash gun that can be controlled from the V6 controller master transmitter.
I don't think the AF 400T can be controlled by the Cactus V6 (it's not listed). There might be other similar controllers that might though. Basically the transmitter/receiver allows you to manually control the output of each of the slaved flashes independently.
Before I got my TTL flashes, I used to use an old Sunpack flash gun that looks quite similar to the Pentax 400T. I used that with another simple slave flash that was much smaller and was simply triggered by the light of the big flash when doing macro photography. We just used to measure the distance from the flash to the subject and work out the exposure that way. It also meant needing three hands (or the camera or flashes on tripods). TTL certainly makes it much easier to get good exposures though (or a TTL ring flash).
I think the Cactus system is more creative in how you can use it (to some degree) but takes a little trial and error to get the exposure right. I imagine there are other similar controllers but the Cactus one is the only one that I have heard of that can use so many different flash guns from so many different manufacturers.
You might be able to put your 540fgz on the K1's hot shoe (running that normally with TTL metering) and use the cable connection on the K1 to fire the 400T (sorry, I don't know if you have that sort of connection for the 400T) but you would need to be able to control the power of the 400T manually I suspect.
Have fun experimenting.
