Originally posted by RobG I'm surprised that they're still using the original engines! They could probably cut from eight to four and still have higher efficiency at the same power.
You listed most of the biggest engine manufacturers other than CFM. That would be a significant contract.
They keep rebuilding the engines, but the costs have become prohibitive.
Several replacement plans have been considered.
Replace the engines with eight of similar size and thrust. This plan results in little, if any change in fuel consumption and operating costs.
Replace the engines with four larger engines with higher thrust. This plan is supposed to result in better fuel efficiency, longer range, and lower operational costs.
Going with the latter plan seems logical, providing they can be fitted and not create ground clearance issues.
But it will change the looks of an icon most of us know and recognize.
