Originally posted by Bertrand3000 Thank you for those wise words, and after thinking about it for a while, you are perfectly right. Nothing say that I could have done better with better skills with the lens, in fact sometimes lack of experience can lead to interesting pictures I would not have attempted otherwise. I was using a powerful hand-held lamp as a light source in order to make the decoration shines, and as you pointed out, even moving it a little change dramatically the scene!
It isn't just a lack of experience, but a willingness to try things that wouldn't normally be done, with the assumption that none of it may work, but you might also get some pleasant surprises. In my lens buying days, I grabbed a bunch of cheap lenses, including quite a few m42 mounts. Those force you to experiment. Same is true with lighting. When all I had was the pop up flash, I'd sometimes cover it with a handkerchief to diffuse the lighting on a macro shot. The occasional success made the efforts rewarding.
