Strange picture pattern
Lens: 35 mm, SMC Pentax DA 18-135mm Camera: Pentax K1 Photo Location: Rovaniemi, Finnland ISO: 200 Shutter Speed: Above 6s Aperture: F4.5
Posted By: Hans Dahl, 02-28-2021, 09:35 AM
Hi Guys,
looking through the images I shot in Jan. 2020 in Finnland I noticed a strange pattern on the two images attached. I wonder, if anyone could help me with the cause for these patterns. The shots was taken on a tripod with 30 sec. exposure time. It was very cold. Having said that, I do not think that the cold could have anything to do with it, because all other pictures came out just fine. Any suggestions much appreciated. Thanks a lot.
Regards,
Hans D. Dahl
---------- Post added 02-28-21 at 09:39 AM ----------
Hi,
I can't believe it, after uploading the images I cannot see the pattern I have been talking about. I guess the image resolution is reduced for upload?
The original images have a volume of 7.9 - 8.6 MB.
I will try to get an image of only a section of the photographs and post them later.
PENTAX K-1  Photo
PENTAX K-1  Photo
02-28-2021, 09:44 AM   #2
Hi,
I took a section of the photo and will post it here.
PENTAX K-1  Photo
02-28-2021, 04:17 PM   #3
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by Hans Dahl Quote
Hi, I took a section of the photo and will post it here.
Are we talking about the fine darker blue vertical stripes?
These appear only appear on a small selection of images, did you try other memory cards... to rule out this as an impending card failure/issue?
03-03-2021, 10:04 AM   #4
QuoteOriginally posted by Kerrowdown Quote
Thanks for answering. All other images on the same SD card were fine.
There are horizontal and vertical blue/white lines in one image and in the other there are lines in the light below the moon.
Thanks anyway.
03-03-2021, 11:07 AM   #5
PEG Moderator
Kerrowdown's Avatar
Thanks anyway.
Have you tried a different memory card?
It still sounds like a partially corrupting card to me, which will only get worse over time until it ultimately fails completely. You can confirm this by seeing if other cards show the same symptoms.
camera, finnland, image, images, landscape & nature, pattern, photo, post, rovaniemi
Strange grid/moire pattern at high ISO, is this normal? mikeSF Pentax Medium Format 9 02-12-2018 09:00 AM
Picture file size, picture pixel size, resizeing picture, discussion panonski Digital Processing, Software, and Printing 11 12-01-2016 08:38 AM
Strange error in picture? RonHendriks1966 Pentax K-01 10 05-03-2012 04:14 PM
K-5 Strange pattern appears on sky's blue color redcurl Pentax K-5 & K-5 II 84 03-09-2012 01:25 PM
Strange K10D noise pattern miriya Pentax DSLR Discussion 6 03-15-2009 10:09 AM
All times are GMT -7. The time now is 10:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
