Originally posted by angkymac I like that over exposure for the plumage. Really shows it well. I tend to under expose on the leaves to saturate their colors, but that overly darkens the backlighted bird.
Good lesson you showed me.
I'll have to experiment with that a bit.
Angky.
Thanks Angky. The original lighting that day would most likely have been too dark to reveal the bird and leaves if I had not used the plus EV. I was using TAV mode, so the plus EV gave the exposure what was needed. Another example is, if I notice some bright sun on some wild flowers and I want the sun light to be reduced to where the color and detail may be revealed more (less glare), then I sometimes will use minus EV such as -.3 or -.7 or -1, depending on what is needed. That is when I am using TAV. Otherwise,, if I am using Manual, I adjust my Aperture, Shutter Speed, and ISO as needed for exposure.
---------- Post added 11-11-21 at 08:37 PM ----------
Originally posted by MikeNArk Good shot of the Heron. It was perched pretty high in the tree and with that backlight and your exposure compensation aided you in getting the shot. Good work.
Thanks. It was sort of far away, and up in the tree like you mentioned. I was glad to still get the detail and exposure to reveal the Heron and the colored leaves. It was overcast, so the use of the plus EV was dealing with an even light and it worked out pretty well.
