Originally posted by MikeNArk Looks like a 3D object in a flat background. Wonderful use of light to make the Joshua tree stand out proudly.
Thanks. I did want to have the tree "pop out" a bit through lighting. Thanks!
---------- Post added 01-19-22 at 08:39 PM ----------
Originally posted by pichaser Your use of the ProtoMachine again shows its usefulness . Did you bracket exposures to get this result ?
I LOVE that ProtoMachines. I do want to point out that although the ProtoMachines light makes it easier, you could definitely do this with a good quality LED flashlight. The advantage of the ProtoMachines, even when not using different colors, is that you can control saturation and brightness. Well, that and it's designed specifically for light painting.
I did not bracket exposures. All the exposures are the same setting and are "stacked" only for the purposes of creating star trails and keeping the noise level down. I did the light painting on the first exposure, and then just let the Pentax click away a few times.
