SMC-DA 12-24 Hyperfocal Test Shots
Posted By: song_hm, 12-13-2008, 11:05 PM
Some PP to open up shadow areas, and sharpening to compensate for poor focusing technique.
12-14-2008, 06:00 AM   #2
dazman's Avatar
You've gotta be happy with those results. Nice shots...nice lens
12-14-2008, 06:07 AM   #3
daacon's Avatar
Mine is quite well used and I see you will get a lot of use out of yours, I really like #1
12-15-2008, 08:20 AM   #4
Thanks guys. I was attempting hyperfocal focus, but I did not get it right on #1 and #3. There are no dof marking on the lens, so what I did was set the aperture, lock focus on nearby object and then recompose. It is touch and go.
Any advise on how to make this more reliable?
12-15-2008, 09:43 AM   #5
jeffkpotter
Guest
After months of using this wonderful lens I have discovered that you can wring the best quality out of it by stopping down to f5.6 from 12-18mm and f8 at 20-24mm. If you stop down more at these settings you will lose quality I promise you. It still has great center resolution at 12mm wide open. See Photozone resolution tests. I figure there are no dof markings because the lens focuses from 7ft. to infinity with a truly miniscule twist of the focus ring, and the short extension doesn't give you much room for one.
12-15-2008, 05:11 PM   #6
QuoteOriginally posted by jeffkpotter Quote
...you can wring the best quality out of it by stopping down to f5.6 from 12-18mm and f8 at 20-24mm. If you stop down more at these settings you will lose quality I promise you.
Good to know. I used f/16 on the first two , and f/6.7 on the third.
12-15-2008, 05:15 PM   #7
netuser's Avatar
Damn, another lens to my "to buy" list.
And damn again, so expensive.
12-15-2008, 05:20 PM   #8
It has become my most used lens.
12-15-2008, 05:26 PM   #9
Do you have a hyperfocal calculator?
There are free ones on the web.
I have one for my iPod Touch
I just calculate the hyperfocal distance, set the lens and shoot.
If the lens focus throw is too short and there are no markings just take the distance from the calculator, judge an object at approximately the hyperfocal distance, pre focus to that and start shooting.
Hope this helps.
joe
12-15-2008, 05:38 PM   #10
cupic's Avatar
You have done well in exposure and composition
cheers
12-15-2008, 05:38 PM   #11
jeffkpotter
Guest
QuoteOriginally posted by song_hm Quote
The images still look good though! When I say that quality degrades if you overstop I am mainly referring to the sharpness you lose due to diffraction. Please keep in mind that I am an insane pixel peeper. It really does pay to study the Photozone resolution tests for this lens. Photozone has done us all a huge favor by posting these.
12-15-2008, 05:45 PM   #12
xs400's Avatar
Nice work, great color. Now i want that lens!!
12-15-2008, 06:30 PM   #13
JMR
Nice photos. It seems Jeff knows a lot about lenses, but I will add my two cents. It is generally recognized that to get maximum depth of field at any given aperture one should focus about one third the distance of the area covered by the picture space. With the exception of macro, if you focus on a tree as an example, one third of the area in front of the subject will be in focus and two thirds behind. But this is just a guideline that works for me most of the time.
JMR
12-15-2008, 08:24 PM   #14
Jimbo's Avatar
I have this lens too and I rotally agree with Jeff. I really do like the len but you have to be dead on with set up or you can can a lot of noise with this lens. I like its range and it is becoming one of my favorites. Good like and noce photo's. JIMBO
12-15-2008, 09:48 PM   #15
QuoteOriginally posted by joelovotti Quote
Do you have a hyperfocal calculator? There are free ones on the web. ... I just calculate the hyperfocal distance, set the lens and shoot. ... just take the distance from the calculator, judge an object at approximately the hyperfocal distance, pre focus to that and start shooting.
joe
Thanks Joe. I downloaded the one from DofMaster. Compared against this to finally figured out how to use the chart.
Found the page. MTF for 24mm is better at F/8 than F/11.
camera, photo
Pentax SMC-A 135mm F2.8 - Test Shots legacyb4 Pentax SLR Lens Discussion 9 04-11-2010 05:18 AM
Misc Test shots with my new SMC Takumar 28/3.5 treebeard Post Your Photos! 2 10-03-2009 01:35 PM
Test shots with SMC-A 1.7 hahifuheho Post Your Photos! 2 11-30-2008 01:51 AM
300/4 SMC Takumar test shots d.bradley Pentax SLR Lens Discussion 2 06-17-2007 11:02 AM
All times are GMT -7. The time now is 08:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
