Originally posted by RICHARD L. Thank you for the tip. I'm still "doing my classes" with the K3 III and the learning curve is a little stiff. I tried a series of far-away pictures of the Saint Lawrence River @ f/8, f/11 and f/16 with this combo. I will probably post my findings next week.
Very well-corrected lenses can peak at f/8, best example is the P67 M* 300 mm f/4 on the 645Z : no need to close more than f/8 as there is no additional gain in sharpness. I noticed the same phenomenon with the P67 90-180 mm f/5.6 zoom on the 645Z : sharpness peaks @ f/8, it is "horrible" @ f/45.
Wide-ranging zooms, in particular, always take some experimentation to find the optimum aperture for centre, edge and frame-wide resolution at each focal length, and on a particular camera. Mostly (though this is quite a generalisation) they're optically best around f/8 - f/11... but this is a tricky aperture range with high resolution sensors, because lens diffraction combined with the sensor's small pixel sizes means that shots are becoming diffraction-limited to some extent. The pixels on the K-3III's sensor are even smaller than those on the K-1, so the effects of diffraction will become noticeable at faster apertures. As such, a lens that delivers sharper results at f/11 than f/8 on the K-1 may deliver its best results at f/8 on the K-3III, beginning to look softer at f/11 and narrower. Experimentation is key... and you seem to do quite a bit of that, which is excellent. It's the best way to learn about any lens (or any piece of equipment, period)...
