Originally posted by normhead We eventually put in a wood stove with a surround to block the cold air from coming down the chimney in the winter.
For some reason we don't get these patterns on the windows in my house, maybe because they are triple pane and when they do get frost on them, it is built up around the edges close to the wooden frames.
When I was growing up on the farm in west-central Alberta, the shop had a 45 gallon steel drum converted into a wood heater in the middle and an uninsulated stovepipe through the ceiling. No insulation anywhere in the shop. On the coldest days, we would have to get the drum almost red-hot to keep the shop warm enough to work in.
Years later when my wife and I bought our first house in Saskatoon, there was a detached garage at the back of the lot that previous owners hadn't bothered to sheet the walls or the ceiling, but there was a manufactured wood heater in the back corner. I would pick up discarded wood pallets and cut them up to make firewood and if I fed the heater every 15 minutes or so, the garage would be warm enough to work in, but it was hard to get anything done because I kept having to add wood to the heater.so often. Before we moved I nailed drywall to the ceiling and walls (no insulation and no mudding and taping) which made it much easier to accomplish things in my garage during the winter.
Thanks for sharing the picture and the story.
