Well, I saw fit to play with them both. It was enlightening, really. I manged to get both starting images looking pretty much like my original variant. I have to say, it wasn't that easy, especially with the "properly" exposed version. Why? well, here are some thoughts:
Both versions are way underexposed in the blue channel. That is, the blue channel is clipped hard at the low end. On the underexposed image, making a strong levels correction on the image luminosity expands both the red and blue channels, keeping the color balance reasonably healthy. Bringing the saturation
up pushes the red channel towards the right as expected. Starting with the "proper" exposed image presents a problem in that levels correction isn't much help. You have both reduce the luminosity and increase its contrast. This is hard to do without curves. Saturation is also harder to fix here because it needs a non-linear transformation as well. This requires mapping saturation to grayscale to do the transform then mapping the grayscale back to saturation. It's not hard, if once you learn how.
Bottom line: in images with enormous saturation, underexposing enables "linear" corrections (levels luminosity + saturation increase) while "proper" exposed images are hard to fix as they are essentially 'overexposed' for the lower saturated elements of the image. This requires multiple non-linear transformations to fix.
For me, the secret to color PP is learning to identify what's wrong with an image and fix those components individually (e.g. saturation, luminosity, a particular color channel, etc.) It's often much harder fixing the whole image as one. Have fun with your PP and future RAW adventures.
-Mark
Originally posted by EddyinGA Mark, I don't mind your using it at all
In fact, I appreciate your having done so.
I guess that at some point in time, I'm going to have to switch to shooting RAW. But, I'm trying to get more understanding of the digital process before I do.
If you don't mind. I'll post the original underexposed shot along with one that is properly exposed. If you see fit to do so. Play with either, or both of them.
Thanks,
Ed
