Breaking the rules
Posted By: Marc Langille, 04-10-2009, 08:46 AM
AKA hummingbirds at 1/90 second OR even 1/60 second!
I thought I would go back through some of my images in 2007, since I had some down time. Every now and then I find a little gem that I overlooked and/or dismissed. I came across 20 some odd hummingbird images that I took just after a heavy downpour late in the evening. The skies cleared approx. 40 minutes later, but only 5-10 minutes of decent light remained before sunset. With a tall task ahead of me, I quickly did a meter on the camera in AV mode. Then I changed the camera settings to M mode, and dialed in my changes for what I wanted.
So why even attempt this? Simply to prove that I could succeed. Of course, understanding light and solid technique is VERY important if you wish to come away with some success in this situation. The greater majority of people would have walked away from this situation when trying to use ISO 200 on a fast moving subject. Obviously the cameras that can shoot very high ISO's with minimal noise would have been the best choice. Faced with those conditions, most would forgo trying to shoot in this situation if higher ISO's were not an option.
What shocked me: in almost all instances, I broke one or even many rules taking these images. The most obvious is the shutter speeds that is almost universally recommended by experienced hummingbird photographers. Normally you would see 1/750 or 1/1000 sec. shutter speed as a minimum. Several people on a forum were in utter disbelief when I informed them (or they checked the EXIF) that I regularly photographed these aerial acrobats at 1/500 sec. I do this shutter speed in M mode for a specific reason: so that I control the image, not the camera.
Rules broken:
  1. Minimum shutter speeds recommended for a fast moving subject (in order to have a crisp image, not blurred artistic), as was the focal length used (300mm). It easily exceeded the reciprocal shutter speed.
  2. EV value at -2 (ie. not exposing to the right)
  3. Kept ISO low during very low light conditions.
Images - taken with the K10D + FA* 300/2.8, cropping around 50% of image (1/90 sec.):
Link to EXIF: SmugMug Photo Sharing. Your photos look better here.
Taken at 1/60 sec.:
These are obviously not magazine material images, so please bear that in mind. Given the shutter speeds involved, I am very pleased with the clarity. I came away with nearly a 50% success rate - several were slightly soft (OOF) due to the aperture used and corresponding DOF. It can be done!!
Regards,
Marc
Last edited by Marc Langille; 04-10-2009 at 11:37 AM. Reason: clarification, two different shutter speeds
04-10-2009, 09:40 AM   #2
daacon's Avatar
Wow if I tried that set up I would have the creamy bokeh you have perhaps and then some sort of unidentifed blob in the middle.
A great example of what can be done. Well done Marc.
04-10-2009, 10:09 AM   #3
You are a professional. Nothing better i can say. Thanks for share your experiments and knwoledge
04-10-2009, 10:13 AM   #4
Jimbo's Avatar
you know my feelings Marc! Thank you for sharing JIM
04-10-2009, 11:38 AM   #5
Marc Langille's Avatar
My apologies - incorrect information
The first image is indeed at 1/90 sec., and the second image is actually at 1/60 sec.!
I've clarified this in the original post. Guess I should pay more attention...
Regards,
Marc
04-10-2009, 12:43 PM   #6
I am amazed how you managed to get the focus just in the right spot within so narrow DOF, in the eyes! Beautiful shots!
04-11-2009, 06:16 AM   #7
QuoteOriginally posted by daacon Quote
Nice commentary Dave on your results...
Thank you for the kind comments!
Cheers,
Marc
04-11-2009, 07:09 AM   #8
Wow! Your images are amazing! I both of them!
04-11-2009, 08:22 AM   #9
Heinrich Lohmann's Avatar
Two gorgeous images Mark, rules are there to be broken or the exception enforces the rule or something like it. Thanks for posting them.
04-20-2009, 10:27 AM   #10
QuoteOriginally posted by juanraortiz Quote
Thank you and it certainly was an experiment! I do not recommend this sort of shooting situation as optimal...
Regards,
Marc
04-20-2009, 11:00 AM   #11
MRRiley's Avatar
You DA MAN Marc!!! Gorgeous images as usual.
Mike
04-20-2009, 01:52 PM   #12
jeffkpotter
Guest
Really sweet shots Marc. I'd say they were perfect!
04-20-2009, 01:57 PM   #13
Damn Brit
Guest
You're just proving the adage "rules are meant to be broken" Marc. You proved it big time. One thing surprises me though, the lack of noise considering you underexposed them.
04-20-2009, 03:16 PM   #14
QuoteOriginally posted by Jimbo Quote
Thank you Jim! Much appreciated...
QuoteOriginally posted by gawan Quote
Thanks Georg! It was a challenge, since it was quite dim at that point - the setting sun was filtering a bit through the leaves of a tree too.
Regards,
Marc
04-20-2009, 03:23 PM   #15
Ash
Ash's Avatar
Marc,
As has been said, these shots take more than just a great lens to have been created...
A darty flying object captured sharp at 1/60?!?
camera, exif, image, images, light, mode, photo, rules, shutter, situation, speeds
Misc Breaking School Rules Sailor Post Your Photos! 7 07-23-2010 01:59 PM
Landscape Breaking up Jimbo Post Your Photos! 17 01-20-2010 03:47 PM
Breaking In My A-50mm F1.4 legacyb4 Post Your Photos! 8 04-09-2009 12:49 AM
Breaking Through... creampuff Post Your Photos! 8 07-11-2008 09:30 AM
breaking it in d.bradley Post Your Photos! 5 03-31-2007 09:04 PM
All times are GMT -7. The time now is 11:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
