How to upload / link photos - BEGINNERS START HERE
Posted By: Adam, 09-06-2006, 08:40 PM
There are four ways of posting photos in your threads:
1. Attach images directly* to your posts
Attachments are files saved inside individual posts. You can attach photos to virtually any post on the forum.
To upload an attachment:
  1. Start a post by clicking the 'post reply' or 'new thread' button, (if using quick reply, skip to step 2)
  2. Scroll to the lower portion of the page
  3. Click the 'manage attachments' button.
You will then be able to upload image files straight from your computer. Any attachments will automatically be shown in your post. You can upload up to 100Mb of photos at once and our system will scale them appropriately if needed. We recommend uploading photos no larger than 1400 pixels wide x 900 pixels tall to avoid auto-scaling.
Important: be sure to click on the upload button in the attachment popup, and be sure to save/submit your post. Otherwise, your attachments won't go live.
Note: you can also attach more photos when editing a post (in the go advanced view) or posting a quick reply.
Acceptable image file types include: gif jpe jpeg jpg png
If you attempt to upload a very large file, our system will time out after reading in more than 100Mb of data or waiting 60 seconds, whichever comes first. You will then be shown a session "token error". To fix this problem, scale the photo to a smaller (web-friendly) resolution before uploading.
To increase your total attachment space, click here.
2. Embed an off-site image
To embed an off-site image, simply place the following code in your post, replacing the placeholder URL with the address of your actual image:
[img]http://www.site.com/image.jpg[/img]
You can also use the button in the visual editor and enter the URL in the prompt.
The URL must be a valid internet address. If your photo is currently on your hard drive, see method #1 instead.
Important: the link you enter here has to point directly to the image, not to a page containing to the image. The easiest way to verify that the link is correct is to check to see if it ends in an image filetype extension, such as .JPG, .GIF, or .PNG.
NOTE: Please embed only reasonably-sized photos. No monstrous filesizes or resolutions!
3. Post images from the User Photo Gallery
To upload an image to the User Photo Gallery, click here.
To then embed your uploaded images, either follow method 2 above, or click the button if using quick reply, or the "insert album photo" link if using the main editor, and proceed to select your photos. Click on a photo to embed it, and make sure you choose the appropriate thumbnail type from the dropdown.
The filesize limit within the user photo gallery is generally 2Mb. There is no resolution limit.
4. Post images from a Personal Album
To upload photos to a personal album, click here.
The filesize limit within the album system is 1Mb, and the resolution limit is 1024x1024px. Larger files will automatically be scaled and/or compressed.
For gallery and album photos, you can also use method (2) given you copy the original URL of your image.
5. Embedding attachments already posted in another thread
Click the button if using quick reply, or the "insert album photo" link if using the main editor, select "albums", "gallery", or "attachments" in the left hand dropdown, and proceed to select your photos. Click on a photo to embed it, and make sure you choose the appropriate thumbnail type from the dropdown. A list of all your attached photos is also found here.
E
XIF Information
EXIF information will automatically be read from any attached photos in your post and displayed in a dropdown above them.
EXIF is also read for photos within our user photo gallery or album system, but is not available when you embed those photos.
Note: EXIF information must be complete in order to be read. Incomplete information (< 8 fields) will be ignored.
Image Sizing
The maximum embedded image width and height are by default constrained to 1024 pixels. Clicking any photo will allow you to view it in its original dimensions. To change these defaults or to disable the resizing system, visit your profile options.
We kindly ask that your embedded photos do not exceed 1Mb in filesize to speed up loading. You are encouraged to use links to large files.
You may want to occasionally check your upload quotas and filesize restrictions here on PentaxForums, as changes are sometimes made without notice!
We used to rely on the [imgwide] BBCode () to embed wide photos in posts. While you may still use this tag (see here for details), it has become deprecated due to the introduction of the auto image resizing system.
Here's some images showing the process of adding an image to a post: Here, showing how to add an image thread here in Post your Photos.
First, this is the page you see when you go to create a thread. I have edited the text as shown.
Next, when a user clicks on the "Manage Attachments" button, the following pop-up appears:
Click on "Choose Files". A screen will appear showing the user's folders on their computer and they can navigate from there to the location of the photo they'd like to upload.
The user should click "Upload" after navigating to the and clicking on the image they'd like to upload.
The "Manage Attachments" pop-up will now display as follows, showing the image (or images) selected.
The "Manage Attachments" pop-up can now be closed.
The member will see the following screen, the "New Thread Screen" as seen before adding the image, now has an image attached.
The member can choose to go and change that attachment, or can simply click on "Submit New Thread" which will complete the thread creation, complete with image.
01-18-2016, 07:41 PM   #166
QuoteOriginally posted by stein Quote
Hi, I'm a newbie here and also fresh Pentax owner. I have loads of decent photos worth sharing but none of those are made with a Pentax camera. (My K-S1 has barely 100 test shots) I'm not sure if it's appropriate to upload (older) images I made with other cameras, after all this is a Pentax forum, not a "whatever camera you have there" forum... ?
You can upload photos from any camera you'd like
01-18-2016, 10:08 PM   #167
stein's Avatar
Thanks.
02-17-2016, 09:06 PM - 1 Like   #168
Try to upload
My first pics in pentaxforums.
Thanks.
https://www.pentaxforums.com/forums/attachments/12-post-your-photos/299186d1455768373-how-upload-link-photos-beginners-start-here-_ktc7074.jpg
PENTAX K-5  Photo
02-20-2016, 12:00 PM   #169
Pewter's Avatar
Waiting in Bugis for the Pentax FF
this could've been me waiting in vain for the Pentax FF
PENTAX K-30  Photo
03-03-2016, 02:11 PM   #170
dcmsox2004's Avatar
trouble with choosing size i want from flickr
hi all.... i've used flickr to post to pf for years... now, when 'copying image location' for size i want to use...
then employing the 'insert image' icon here, it only posts a smaller size.... never had this problem till now...
(i've been away from the forum for quite some time, and would like to post the size(s) i want)
regards and thanks...
dave m
04-21-2016, 10:18 AM   #171
Super-Multi-Coated TAKUMAR 120mm F2.8@f2.8 on Pentax K3
04-21-2016, 10:23 AM   #172
Otis Memorial Pentaxian
photolady95's Avatar
QuoteOriginally posted by dcmsox2004 Quote
hi all.... i've used flickr to post to pf for years... now, when 'copying image location' for size i want to use... then employing the 'insert image' icon here, it only posts a smaller size.... never had this problem till now... (i've been away from the forum for quite some time, and would like to post the size(s) i want) regards and thanks...
Instead of using "Insert image" use the BBcode in flickr after clicking the arrow in flickr, chose your size and just paste the link into your post.
04-24-2016, 05:19 AM   #173
BruceBanner's Avatar
Hi all!
So noob question. I use flickr, have a thousand or so pics, I do not want to start uploading pics here, but being a new Pentax owner thought I might just simply post a url link to new albums I make along the way (such as this one I did this weekend; https://www.flickr.com/photos/moonpussy/albums/72157665177879834)
Is this place only for actually embedding pics to the forums? I'm pretty lazy and dunno if I can be bothered with that, but perhaps using this community here to just say "yo peeps, some new pics from this weekend/event, check 'em out here" etc. Is that a done thing around here? My thinking was that several people here might use flickr, can comment direct on the pic there in flickr land, possibly add me (and I they) etc, make new pentax flickr pals etc?
Cheers,
Bruce
05-04-2016, 08:46 PM - 1 Like   #174
Pentax K-S2 Kit Lens photos (for the curious)
Relocated on advice from Admin
05-04-2016, 08:51 PM   #175
QuoteOriginally posted by BruceBanner Quote
Hi all!
Cheers,
Bruce
You can include Flickr pics in threads in this forum. Those will link back to your Flickr page too, but I think most commenting is done here, for convenience.
05-04-2016, 08:53 PM   #176
QuoteOriginally posted by Sean Hamilton Quote
Very nice! You should post these in their own thread for more comments
05-04-2016, 08:59 PM   #177
Thanks Adam! I should have yes, but realized just NOW that this was not the generic post your photo's thread - and just thought some kit lens examples (as it is sometimes maligned) might be beneficial; as I thought these turned out pretty good. Seems wasteful to re-post the exact same pictures to a dedicated thread, no?
Edit: Ok, it wasn't THAT hard to re-submit
05-06-2016, 09:09 AM   #178
I want to upload a RAW file here for advice on post processing. I am unsure as to what look would be best as the final result. The file is of size 11 MB. How should i do it ?
05-07-2016, 07:36 PM   #179
QuoteOriginally posted by Urnamaster13 Quote
You cannot upload raw files to the forum. You will need to use an external file host, such as Dropbox or google drive, and then post a link to it.
05-09-2016, 12:29 PM   #180
QuoteOriginally posted by chochobo Quote
very fine shot
address, album, button, camera, click, dropbox, filesize, gallery, google, image, images, insert, limit, option, photo, photos, post, quality, test, thread, upload
True Beginners - READ THIS / START HERE! Heie Troubleshooting and Beginner Help 25 04-02-2016 08:31 AM
How to upload photos from K3 to computer Bob Harris Pentax K-3 & K-3 II 34 10-19-2015 10:42 AM
How to upload photos - BEGINNERS START HERE Adam Site Suggestions and Help 1 05-21-2014 09:30 AM
How to post Flickr photos here ? Michael Piziak Troubleshooting and Beginner Help 37 01-19-2014 08:36 PM
Question Unable To Upload Photos DavidSKAF3 Site Suggestions and Help 3 12-17-2013 05:43 PM
All times are GMT -7. The time now is 05:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
