Line around flower?
Hey Freddie, just noticing a lasso selection line around the flower. It looks like you have lightened the background but not the flower. I can see on my monitor this line showing up quite clearly.
What I would try is do a very loose lasso selection around the flower, feather it and then use "select colour range" and select just the white areas. Then with the selection loaded, adjust levels with an adjustment layer. Using the adjustment layer will leave the original photo as is, and never permantently altered.
These are sort of steps we use a lot of the time when we(my work) adjust food styled photos.
Oh i guess this will only work for you if you have a decent version of photoshop.
Hope this helps
Doug
