Betsy,
There are no tricks to pano or mosaic photography. There are a few cardinal rules
that will suffice.
The hardest part of a journey is the first step (orignal thought
The best thing you can do is what you have done. The scenery is gorgeous and deserving of viewing...
presented as you have. I see the scene...not the pixels.
What would help here are:
A high end tripod (mine is over 10#'s but I always take it when hiking)
Set your camera to manual and shoot from a leveled tripod (level in all directions as you rotate is the
key
trick here... it ain't as easy as it sounds.)
Do at least three runs by bracketing to the underexposed side of the equation.
(The reason for this is that you take your meter reading on the point of interest and that is usually the "average exposure".
As you turn the tripod head the sky will lighten and wash out. Bracketing to the under exposure side gives you some leeway.
In the image you have here you can also add an extra row of images pointing down about 5 to 10 degrees to give the pano more
vertical height and more detail. I would suggest a pano head for that. Nodal Ninja is great but cost 200.
It is well made. The more foreground you put in the more parallax problems you encounter and the more trouble any stiching
software has pulling it all together.
Learning to use a pano head correctly will eliminate parallax problems.
I use PTGui (99.00) and find it works wonderfully. Huggins is free and may actually be PTGui interface wise. CS2 stinks at panos...
but is great at reworking the PTGui layered panos. The greatest feature of PTGui for me is that it is that the blending engine just
seems to work nearly perfectly.
I'm new to this stuff too. It is a headache to learn it all but the rewards are really worth it in situations such as you have shown above.
Great start here... I hope you dive in here and show us more of the beauty of Oregon and Washington.
Drop me a line if there is anything else I can do for you.
Stephen
