Originally posted by IowaBoy No I don't mind at all. Thanks for taking the time to play with it. Your crop does pull the eye to the building.
I tried all last summer photographing this same area w/o any results I liked. The trees and leaves overpowered the scene - even in the Fall color season. Now that I have seen it in winter I will return & explore other angles. 5 inches of fresh snow today
Work with your widest possible lens and get as close to the fence line as possible. I wouldn't worry about how the tree effects the look. As long as you focus on the building and use a DOF which *slightly* puts out the tree you will be fine. Also, the simple reason why your eye travels to the building is because it is the only illuminated subject in the frame. Try getting everything set up just before the time you took this image, tripod, lens, camera config, light metering, everything, wait for the light to position itself and voila. Bet you'll be happy.
