Hi folks!
I just read here that a new firmware for my K-500 is out (which is a great little cam, btw., that blew me away after 8 years of *IST DL2).
I downloaded the update and copied it to a freshly formatted SD-card. But the cam does not recognize it and does not offer the update-option!
The steps I did:
1. Download and unpack the zip.
The unpacked file is named "fwdc223b.bin" and has an exact size of 12.845.056 bytes.
2. Formatted an SD-card using the cam.
3. Copied the file to the card using a card reader. (Root, of course; no sub-dirs there after formatting
4. Put card in cam and powered on.
Oh yeah, battery is 100% full (using the orignial one delivered with the cam, no alkalines or else).
5. Opened the menu and went to "Firmware Info/Opt."
It shows me that I have 1.0
That was it. Nothing else. No way to go on!
According to the video tutorial as well as the PDF that can be dowloaded with the firmware I have to press the "right" button another time to open the update screen. But that does not happen.
I tried playing around with that, used another SD card and even swapped the battery (using "AA" with the adapter I have) - but nothing helped: The update screen does not come up.
Oh yeah, before I forget - I found 2 copies of the file; one via the german support site and one from ricoh-imaging.jp.com. But they seem to be the same.
What have I missed? Or is there a problem with the update file?
Is it necessary to update to 1.01 first?! (would be stupid) And if yes, where to get THAT?
It's not that I do really need the update, but usually they improve general performance or quality a little bit by tweaking or optimizing some stuff; so even if I don't own any hardware that is introduced here I'd be glad to have it
Thanks for any help in advance!
B.
