Was interested to see how the 200 performs with the Q, shooting a distant subject. Adapter is a inexpensive PhotodioX.
So I took a picture of the lighthouse. Note the size of the 3rd order Fresnel lens in comparison with the tourists. Actual pixel crop.
Shooting across 1/2 mile (0.8 kilometer) of water may have affected sharpness, and my technique still needs work. 1/250th second may be too slow for best sharpness. Aperture is F8.
If you want to compare the same subject taken with a 600mm combination (as much as comparison is possible with a 2 second exposure), check out my
post in the 300+ club.
Highlights reduced on over exposed areas, some sharpening done, otherwise not much PP. Some CA visible.
At the other end of the spectrum is a blue surgical cotton towel photographed with the Q & 200, 1:1, at f8. Actual pixel crop. Highlights reduced, some sharpening done.
Decrease the small thumbnail of the original image to Q sensor size if you are interested in the dimension of the weave.
Does anyone else have any Macro lens with Q images to share?
