07-03-2018, 03:16 AM   #2896
PEG Moderator
Kerrowdown's Avatar
Dancing In The Morning
07-03-2018, 03:16 AM - 2 Likes   #2897
PEG Moderator
Kerrowdown's Avatar
Full Glory
07-03-2018, 05:47 AM - 6 Likes   #2898
Scorpio71GR's Avatar
QuoteOriginally posted by WPRESTO Quote
I have long since found that I get far, far more keepers using flash. I like to go out early AM, especially about September, "bug hunting." Using a tripod-mounted camera and natural light to avoid the black backgrounds typical of flash images, far too many of the images are slightly soft because of subject motion. For insects, if I cannot use at least 1/200, the risk of motion blur is too great for me. Hard enough to find subjects - - no way I'll risk losing such opportunities using a technique that has proven unreliable in the past.
We have one of the largest indoor butterfly exhibits in the United States here in the spring. Over the years I tried all kinds of techniques. Eventually I settled on using a flash. The lighting in the conservatory is terrible. Some places are so dark it is difficult to achieve proper focus. I usually get two looks. One is of dismay at my use of unatural light. The other is of curiosity. I will get asked how I manage to get pictures to turn out with the flash. On my K3 I made a User setting to utilize HSS. I use the same settings on the K-1. ISO is maxed at 400, Tv is typically around 1/200-1/400s, apeture varies for Dof requirements. I adjust the output of the flash as needed. I have found the PTL on the AF 540 FGZII to be pretty reliable. I bring along a few diffusers and a soft box. I would be lying if I did not admit the whole thing is still trial and a lot of error. However learning as you go along is part of the experience. The plus end for me is an image like this.
K-1, Sigma 180 Macro, AF 540 FGZII, and Gary Fong diffuser.
ISO 400, 1/400s, F11
07-03-2018, 07:39 AM   #2899
ChipB's Avatar
QuoteOriginally posted by Scorpio71GR Quote
Very nice Michael - I'll have to try using flash in the future.
07-03-2018, 04:35 PM   #2900
QuoteOriginally posted by ChipB Quote
Thank you Chip, I have both versions of the AF 540 flash. The second and current version is by far the best flash I have ever used. The AF 540 FGZII is a completely different flash the original. I need HSS flash and AF 540ii seems to work best for that plus it is weather sealed.
07-04-2018, 02:35 PM - 1 Like   #2901
Weevil's Avatar
Moth behind bars
Look closely for details.
2018.07.04, Saint-Jean-sur-Richelieu, Québec, CANADA
Noctuelle de Baltimore* / Baltimore Snout [Hypena baltimoralis]
(*Nom français à valider)
Technique:
Empilement de 12 images / 12 images stack (Zerene Stacker / PMax method)
Pentax K-1 + SMC Pentax-D FA 50mm F2.8 Macro
1/4s, ƒ/8, ISO 400 g(lumière naturelle / natural light)
Noctuelle derrière les barreaux / Moth behind bars
(x-posted)
07-04-2018, 03:58 PM   #2902
UncleVanya's Avatar
QuoteOriginally posted by Weevil Quote
Moth behind bars
Technique:
(x-posted)
Very impressive. I have never gotten around to stacking but this is a reason to learn it.
07-04-2018, 06:41 PM - 4 Likes   #2903
A few from my Vivitar/Pentax/Cosina/et all.... 100mm f/3.5 Macro
07-04-2018, 07:06 PM   #2904
jonhock's Avatar
Us "Dabblers"...
QuoteOriginally posted by Aslyfox Quote
IMHO
you have dabblers ( talented and/or less - me - ) or people who specialize
in many areas of photography
this is especially true with macro
use of different techniques
" field " vs. " lab "
the benefit of being a dabbler using a true macro lens - the lenses are generally very good for photography even if not used for macro
Exactly and Amen! I have the Pentax 35mm 1:2.8 limited and a Sigma 105mm 1:2.8 DG Macro. I use both a LOT more as "regular" lenses than I do macro.
---------- Post added 07-04-18 at 10:12 PM ----------
I've been trying to learn macro ever since I screwed a Spiratone extension tube between my Asahi Pentax S and its f2.2 pre-set Takumar, but sometimes I still foul up.
I've been trying since about 1978 when I used a reversal adapter on my K1000 with my Pentax A 50mm 1:2. Yeah, those were the days (I still have the adapter)
07-04-2018, 07:34 PM   #2905
WPRESTO's Avatar
QuoteOriginally posted by jonhock Quote
I still have the zebra-stripe Spiratone extension-tube set, and still use them, albeit rarely.
07-05-2018, 03:14 PM   #2906
jonhock's Avatar
Not too much else, though....
Just offhand, I can't think of anything else that I have left over from that year. 1978 was my first year with an SLR. I remember telling my wife that I wanted to get a "Real" camera and got the K1000 at K-mart Anyway, getting off the macro track so I'd better stop reminiscing on this thread and post a couple photos with my Pentax M 100mm macro and my first DSLR, the K10D. This was my second dedicated macro lens after the 50mm 1:4 macro. I was testing what I had read about ways of figuring out how much magnification a lens produced in February of 2012. (Well, maybe a little reminiscing)
PENTAX K10D  Photo
PENTAX K10D  Photo
07-05-2018, 03:28 PM   #2907
WPRESTO's Avatar
I have three items from my very early days with 35mm, all which have survived multiple changes of cameras: 1) the Spiratone extension tubes; 2) a Pentax close-up filter specifically designed for their normal focal length lenses because when it is attached, focus starts at the close-focusing point of the normal lens without the close-up filter; and 3) a Braun two AA cell all-manual strobe that still works perfectly except that the slide-off battery compartment door is too loose to be trusted (I wrap a rubber around when I sometimes use the flash). Of these, the extension tubes are the oldest SFAIR.
07-06-2018, 10:52 AM - 3 Likes   #2908
Mike.P®'s Avatar
Just noticed a little moth on the wall so grabbed the K3II and 100mm WR to grab a couple of shots.
Portrait of a Moth
by Mike.Pursey, on Flickr
Moth
07-06-2018, 01:09 PM - 1 Like   #2909
ChipB's Avatar
QuoteOriginally posted by Mike.P® Quote
Portrait of a Moth
Moth
Well shot Mike.
07-06-2018, 02:24 PM   #2910
Canada_Rockies's Avatar
Nice shooting, Mike.
club, composition, da 18-55 wr, da 35 mm, ebay, extension, extension tubes, flickr, focus, idaho, k-5, lens, lenses, macro, macro lens, macros, pentax lens, post, quote, shot, shots, sigma, sigma 180mm, smc, sw, tamron, test, thread, vivitar
The Raynox Macro club audiobomber Lens Clubs 947 10-08-2022 03:12 PM
The * lens club BrendanPK Pentax SLR Lens Discussion 56 08-13-2017 12:38 PM
The *any and all* lens club yeatzee Lens Clubs 37 11-08-2012 04:50 PM
The 'Hey this lens has glass elements in it' Lens Club Igilligan Lens Clubs 50 11-14-2010 11:07 PM
Macro Macro mania at the photo club MoiVous Post Your Photos! 11 04-14-2010 06:02 PM
All times are GMT -7. The time now is 07:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
