Show Printable Version 5966 Likes Search this Thread
05-09-2022, 09:46 AM - 1 Like   #4546
WPRESTO's Avatar
QuoteOriginally posted by que es tu Quote
Well, I finally got around to testing this, and here is what I found out: the 55-300 f4-5.8 @ 300mm with the Canon 500D closeup filter at MFD shows 25mm
I also now have a DFA 100mm macro, and that lens shows just over 23mm. Pentax says the sensor is 23.5 mm wide, so that should be perfect.
Just for fun, I put the closeup filter on the macro lens and got 18.5mm. So, 5% above life sized??
I suppose the 55-300 gives just under life size with the close up filter which is good enough for me!! Thank you for your help!!
Let me give you some caveats:
1) Achromatic lenses generally work better at modest focal length. The best IQ with a 55~300mm + 500D* will probably be in the 75~200mm range
2) At about 1/4 life-size the depth of field starts to get really, really shallow. Focus is critical (move the entire camera + lens, the focusing ring and AF will not be useful)
3) Also at about 1/4 life-size, camera shake becomes a major issue. At that magnification it's like trying to hand-hold a 500mm lens @ 1/60 0f a second
At about 1/4 life-size and greater magnification it's best to use a tripod and/or a strobe, otherwise too many images will fall short because the focus wasn't right or because of blur caused by camera shake. A tiny breeze in the field, trying to photograph an insect at say 1/3 life size, will throw your subject far out of focus, blur it badly, and even push the subject completely out of framing. If you do macro in the range of 1/4 life-size and greater magnification, you need different technique and a high tolerance for images that don't turn out as hoped or expected.
* Canon's "500D" designation is supposed to indicate that when attached to any lens that is focused @ infinity, the 500D will bring the focus distance down to 500mm (= 0.5m). The Canon 250D brings to focus distance down to 250mm (= 0.25m). This applies to any lens, any focal length, prime or zoom, when the lens is set to infinity.
05-09-2022, 11:34 AM   #4547
que es tu's Avatar
QuoteOriginally posted by WPRESTO Quote
* Canon's "500D" designation is supposed to indicate that when attached to any lens that is focused @ infinity, the 500D will bring the focus distance down to 500mm (= 0.5m). The canon 250D brings to focus distance to 250mm (= 0.25m).
Yes thank you! I have noticed all of your points since I began dabbling in macro photography. Coincidently, I just discovered that I can use my Godox TT350 with the 100mm macro and get much higher keeper rate. DOF and subject movement are a real challenge, but I have taken some nice shots since I started using the flash. My “photo budget” will be caught back up soon, and I hope to be able to donate so I can post photos and get feedback. Until then I will study everyone’s work here and keep learning all I can. Thank you again for your advice!!
05-09-2022, 01:03 PM   #4548
WPRESTO's Avatar
Some people don't like the black background in macro images taken with a strobe, but for me the % keepers and the much superior rendering of details is more than sufficient compensation.
BTW: I also like the Vello Universal Flash Diffuser for softening a strobe for close-ups. It's a little snug to get onto bigger flash units, but it's only $10.
https://www.bhphotovideo.com/c/product/749295-REG/Vello_VE_1001_Universal_Bo...981&
05-09-2022, 01:39 PM   #4549
que es tu's Avatar
I have been experimenting with shutter speed to change the background illumination. I also discovered that the focus clamp on my old DFA 100mm macro acts as a MF/AF switch so when I engage the clamp, I can utilize Catch-in-Focus! I get the subject almost in focus, then slowly move towards it until the shutter clicks and the flash fires, and bada bing bada bang!! I have the photo!! The trick is to move very slowly. I haven’t tried a flash diffuser yet, but will look into it as my interest and experience grow.
05-09-2022, 03:16 PM   #4550
WPRESTO's Avatar
Catch-in-focus is really useful. Another useful method is to set the camera to the fastest multi image rate you can, manual focus, focus peaking if available. Then when moving the rig forward and the subject first gets peaking color, press and hold the shutter and move forward-back slowly across a very small distance. Numerous discards, but one will probably be just what you hoped. If your movement is close to linear and the subject does not move, you might be able to image-stack a few frames to gain some DOF. I've used this method on insects with some success. Stacking a few frames is sometimes possible, but insects what have antennae, especially long antennae, seem to move them constantly. A few stacks I tried yielded an insect with a forked antenna that was unknown to the natural world.
05-09-2022, 11:03 PM   #4551
simon_199's Avatar
Yes stacking of live creatures at close to 1:1 magnification is extremely challenging. Handheld with no flash, then I'd say borderline impossible beyond a couple of frames out of sheer luck. I've seen many stunning stacks of several tens of frames of live insects, but they were done in very specific moments of the day like early morning at low temperatures, where insects are asleep and can be approached with all the necessary equipment (tripod, focusing rail, etc).
05-10-2022, 02:14 PM   #4552
QuoteOriginally posted by simon_199 Quote
Insects that don't move may be easier to photograph, but they are also harder to find. For that reason, the first thing I pack is a pair of Papilio II 6.5x binoculars.
05-12-2022, 11:15 AM - 5 Likes   #4553
jcdoss's Avatar
Pentax K-1 mII Ltd Silver and A*200f4 Macro
05-13-2022, 04:21 AM - 1 Like   #4554
WPRESTO's Avatar
QuoteOriginally posted by jcdoss Quote
That's a visually pleasing image. The lighting makes it as much as the the sharp details.
05-13-2022, 07:34 AM   #4555
que es tu's Avatar
Until I can donate and use attachments, I put some photos in my album entitled “ Macro Work”
05-13-2022, 08:19 AM   #4556
jcdoss's Avatar
Thanks for the kind words!
05-14-2022, 11:37 AM - 2 Likes   #4557
Large red damselfly and victim (Tiger Sawfly?). Sigma 180mm/5.6 with 20mm extension tube, KP, natural light.
05-14-2022, 11:45 AM - 1 Like   #4558
que es tu's Avatar
I took this while waiting for my son to finish his circus arts class. Pentax 100mm f2.8 macro with Canon 500D close up lens f11 ISO 200 1/60 Godox TT350 flash handheld
05-15-2022, 07:37 AM - 1 Like   #4559
que es tu's Avatar
Here’s another one just for kicks! I focused on the “eye”, but the DOF was tough to deal with!
05-15-2022, 11:51 AM - 2 Likes   #4560
que es tu's Avatar
I thought this one turned out kind of interesting. It is a red clover blossom with the DFA 100mm macro and the Canon 500D close up lens. f8 1/60 ISO 800 handheld no flash
club, composition, da 18-55 wr, da 35 mm, ebay, extension, extension tubes, flickr, focus, idaho, k-5, lens, lenses, macro, macro lens, macros, pentax lens, post, quote, shot, shots, sigma, sigma 180mm, smc, sw, tamron, test, thread, vivitar
The Raynox Macro club audiobomber Lens Clubs 947 10-08-2022 03:12 PM
The * lens club BrendanPK Pentax SLR Lens Discussion 56 08-13-2017 12:38 PM
The *any and all* lens club yeatzee Lens Clubs 37 11-08-2012 04:50 PM
The 'Hey this lens has glass elements in it' Lens Club Igilligan Lens Clubs 50 11-14-2010 11:07 PM
Macro Macro mania at the photo club MoiVous Post Your Photos! 11 04-14-2010 06:02 PM
All times are GMT -7. The time now is 06:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
