Show Printable Version 5966 Likes Search this Thread
07-27-2022, 11:21 PM   #4636
QuoteOriginally posted by WPRESTO Quote
A tiny (tiny!!) spider that had spun its orb web across the two upturned edges of a leaf. Zeiss Milvus 100mm f2, Canon mount via adapter on a Panasonic GX8
That looks tiny indeed, am i mistaken or is the spider slightly out of focus? The water droplets seem sharpest.
07-28-2022, 03:05 AM - 3 Likes   #4637
WPRESTO's Avatar
QuoteOriginally posted by HoutHans Quote
Could be the focus is not spot-on. It may also be a consequence of a significant crop as it was not possible to get in closer because of surrounding foliage = moving would have shaken the plant on which the spider built its web, and there go many if not all the water droplets that really make the image.
FYI: Here is the uncropped image. Notice that I also rotated the image clockwise to get the top edge of the web approximately level.
DMC-GX8  Photo
07-28-2022, 10:53 PM   #4638
FDY: Here is the uncropped image. Notice that I also rotated the image clockwise to get the top edge of the web approximately level.
Wow, that's a significant crop indeed! All the more impressive. And a very very small spider.
07-29-2022, 11:15 PM   #4639
mroeder75's Avatar
Very nice.
08-01-2022, 06:35 AM - 5 Likes   #4640
Synaphe punctalis? K-3 III at 1:1 with a Schneider Xenon-Zirconia 2.8/89-0001 line scan lens (now renamed Zirconia 0.09/1.0x V48), illuminated by bounced flash.
08-05-2022, 09:14 PM   #4641
QuoteOriginally posted by wkraus Quote
Nicely done with lots of detail. This would also be a nice subject for pixel shift. I shot a moth a few years ago in the woods with natural ligtht. It had long scales on the trailing edge of the wing, similar to yours. It was an unusually still day. Pixel shift clearly revealed the the ends of the scales were serrated. Pixel shift is probably a bit more challenging with the K-3 III than the K-1 I was using.
08-06-2022, 03:33 PM   #4642
QuoteOriginally posted by rgknief60 Quote
Thank you! Pixelshift would be great for a subject like this especially with a high-resolution lens, but is not an option with flash.
08-06-2022, 07:44 PM - 1 Like   #4643
Especially if you are working handheld. The bounced flash worked great to reduce the shadows.
The only way I've heard to do it is using a tripod with a low light setup so one can trigger the flash manually for each of the four shifts. I wish Pentax would incorporate a flash signal for each of the shifts so it could be done automatically. The flash would need to cycle fairly quickly, or fire at 1/32nd or 1/64th to make all four.
XPost. Was mostly breezy, so am thankful for this bit of calm while I captured this bumblebee. Distance to flower was 10-15 feet, so was happy with this deep crop. K-1 & 200mm
Pink Coneflower with Bumblebee
08-07-2022, 10:30 PM - 6 Likes   #4644
Weevil's Avatar
Éphémère de ruisseau photographiée sur un cadre de porte. / Stream Mayfly captured on a door frame.
Note: species incerta / Uncertain species
D'après iNaturalist, il semble que ça correspondrait for possiblement à l'espèce suivante: / According to iNaturalist it's pretty sure that the species is:
Maccaffertium modestum
Fam. Heptageniidae
Order Ephemeroptera
Heptagénie modeste / Modest Flat-Headed Mayfly [Maccaffert? | Flickr
Heptagénie modeste / Modest Flat-Headed Mayfly [Maccaffertium modestum] sp. inc., Fam. Heptageniidae
#PENTAX
Pentax K-3 + SMC Pentax-D FA 100mm f2.8 Macro WR
[EXIF in flickr]
08-12-2022, 10:29 PM - 2 Likes   #4645
Here is a video of a cicada emerging and pumping up it's wings. I gave it the opportunity to climb from the chain link fence to a stick so I could relocate and better document the process.
The video is composed of several videos spiced together. The total shooting time was about 1:15 over a span of 1:45. I I batch edited about 139,000 frames and re-encoded most of the video at 120fps to shorten the watching time to 19 minutes.
The light was relatively low. It was shot using my K-1 and 200mm last summer. I was unable to get any usable footage in the low light using a K-3 III. That may or may not be the camera's fault.
This is one of my few efforts at video, and it shows. Go easy on me! I hope you find the metamorphasis interesting.
Due to file size (medium quality > 3GB) I was unable to upload the video to flickr, so it is on my Google drive. As it takes up a fair bit of the free drive space, It will only be there until I need the space for something else. Xpost
08-14-2022, 01:40 PM - 4 Likes   #4646
Dry paeony leaf. K-1 and Tokina AT-X Macro 90mm 1:2.5, focus-stacked from twenty frames taken at f/5.6 with ZereneStacker (crossposted from Tokina Bokina AT-X 90mm f 2.5 Macro and More thread).
08-14-2022, 03:55 PM - 1 Like   #4647
WPRESTO's Avatar
Wonderfully executed studio image. Lighting is perfect.
08-15-2022, 03:16 AM   #4648
Thank you kindly! This was natural window light – if you will, the late 19th century portrait studio technique…
08-15-2022, 05:27 AM   #4649
WPRESTO's Avatar
I believe the ideal was a room with large windows on the north side, to obtain soft natural lighting.
08-15-2022, 07:57 PM - 6 Likes   #4650
Basil. Got sort of carried away: 459 image stack, manual rack & pinion rail. I trashed the first stack attempt as it is too hard to edit without slabs when the DOF is so thin. I started over to obtain slabs from which to edit. That made all the difference. It was a couple hour edit in Zerene, followed by levels in Faststone. Cropped a bit of stacking artifact off the bottom. Second image is actual pixel crop.
Basil Number 2
Basil Number 2 - Actual Pixel Crop
club, composition, da 18-55 wr, da 35 mm, ebay, extension, extension tubes, flickr, focus, idaho, k-5, lens, lenses, macro, macro lens, macros, pentax lens, post, quote, shot, shots, sigma, sigma 180mm, smc, sw, tamron, test, thread, vivitar
The Raynox Macro club audiobomber Lens Clubs 947 10-08-2022 03:12 PM
The * lens club BrendanPK Pentax SLR Lens Discussion 56 08-13-2017 12:38 PM
The *any and all* lens club yeatzee Lens Clubs 37 11-08-2012 04:50 PM
The 'Hey this lens has glass elements in it' Lens Club Igilligan Lens Clubs 50 11-14-2010 11:07 PM
Macro Macro mania at the photo club MoiVous Post Your Photos! 11 04-14-2010 06:02 PM
All times are GMT -7. The time now is 07:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
