Originally posted by stormtech Beautiful shot! Spring flowers in February - man I need to move south!!
Thanks! Just a few blossoms for now, but this is the usual time for the first appearance of Claytonia, Trout Lily, and Hepatica. On the down side, summer is not so good for flowers here; have to get up to the mountains then.
Originally posted by stormtech I do a lot of flower shots in the summer of my wife's many gardens - my main shooting that time of year. I see you used off camera diffused flash - would you mind sharing your setup?
I'm just getting into flash, so still experimenting. The camera was on a tripod and that allowed me to handhold the flash and diffuser in different positions. I just used a piece of translucent polyethylene (cut from a bottle) as my diffuser. I plan to get a small-ish softbox to attach directly to the flash, and some sort of clamp and flexible arm to allow me to attach the flash to a tripod leg. I'm using a 70mm macro lens so the working distance is pretty small at 1:1, hence the need to get the flash and light modifier in close to avoid having the lens cast a shadow on the subject; an umbrella would have been too big for this case. Also it's a question of light fall-off -- whether you want a close-in light source to isolate the subject, or something farther away for better background illumination. So I think the umbrella will serve you well for shots of massed flowers.
