Originally posted by tcbubbleleo very nice
Thank you.
Originally posted by baro-nite Having done a bit of macro with diffused pop-up flash, I've enjoyed looking at these. Problem with this set-up is that in M mode the pop-up flash always fires at full power, and here you're getting blown out highlights. Try stopping down (and make sure you are on the lowest ISO setting) to control the exposure.
Thanks for the input. I have also used external flash but the camera became so much heavy. So with the fact that I never use a tripod, pop-up flash becomes my first choice.
I will try another set up.
Originally posted by Ash Sharp captures, brightside. Lovely rendition.
Indeed they are a little on the overexposed side, but you can get good results with your setup.
Thank you.
