11-17-2022, 03:11 PM   #616
Weevil's Avatar
QuoteOriginally posted by Thagomizer Quote
Yes, that's the case. It does eat up a bit of working distance, but it's an easier solution than jamming something against the lens's aperture control tab. An adapter with aperture control for mirrorless is going to use up more working distance, so going for an adapter intended for DSLR is going to be more convenient.
Wondering if the PK to Q adapter would also do the job... hummmm
01-22-2023, 10:30 PM - 4 Likes   #617
steamloco76's Avatar
These images were recorded at nearly twice life size (2:1) and further cropped.
K-70 with D FA 100/2.8 WR Macro and a variable extension tube, FULLY automatic, made from a Vivitar Macro Focusing Teleconverter with its optics removed. My Vivitar converter had the "A" contacts which allow full, accurate aperture control via the camera. The Vivitar Macro Focusing Teleconverter is fairly uncommon in KA mount, and is just so-so as a teleconverter, but it works great as an extension tube!
01-25-2023, 09:49 PM - 4 Likes   #618
Just found this club
Here I used a 70-200 F4 along with a 1.4 converter and a M 50mm .14 reverse mount on the end.
I mainly use this setup for photographing image sensors and snowflakes.
The sugar grain photographed above was for testing
02-06-2023, 07:59 PM - 8 Likes   #620
Here I used a 70-200 F4 along with a 1.4 converter and a 50 1.8 G reverse mount on the end
02-06-2023, 11:00 PM   #621
Weevil's Avatar
QuoteOriginally posted by Ian Stuart Forsyth Quote
Wow ! just wow !
02-07-2023, 12:03 AM   #622
QuoteOriginally posted by Weevil Quote
Wow ! just wow !
Thank you
02-07-2023, 11:55 AM   #623
swanlefitte's Avatar
Incredible. Is there a reason for the "g" I assume nikkor for this? Any particular advantage or just a good 50?
02-07-2023, 12:46 PM - 2 Likes   #624
One of the things I like about the Nikon G is that the filter ring is not attached to the front element, so when the lens is focused it will move the elements of the lens in relation to the front of the 70-200.
This helps aid in getting the best from from the setup
I did use a pentax M 50 1.7 but found it better with the G
Here is the setup using the M 50 1.7
02-07-2023, 01:02 PM - 3 Likes   #625
Salt and Peppercorn at 5x magnification
Pentax K-1 Laowa 25mm 2.5x-5x ultra macro lens
ISO 100
1/6s at f/5.6
Both are 7 shot focus stacks merged and processed in Affinity Photo v 1.9
02-08-2023, 01:29 AM   #626
Can I join in the awe? These are amazing shots and thanks for sharing the info about the setup! How do you organise the light in this setup? My guess is some diffuse light from below, but I'd love to learn more about this.
02-08-2023, 12:07 PM - 2 Likes   #627
QuoteOriginally posted by HoutHans Quote
For the main light source I used a flash with a blue dvd case attached to create the light to dark blue background I tipped the case and light 45 degrees to the image plane about 4 inch away. A second flash was added of to the side and above the flake to supply highlights to some of the edges. I found it looked more natural to add the light for the highlights to the side with the lightest blue backdrop.
You can increase or decrease the amount of variation of the blue to black backdrop by changing the angle of the dvd case, what is nice using this method is that tonal range will always fall in the center of the frame as long as the dcd case is relatively centered within the frame and you set your exposure based on the lightest you the background to be.
Depending on the flake I may also add a second highlight flash. I also used a low power led light for framing and focusing as to not melt the flake during the preparation.
02-08-2023, 08:54 PM - 7 Likes   #628
More using the same setup
02-08-2023, 11:21 PM   #629
Excellent shots and thanks for sharing this info. I'll try to build something similar and then all we need is snow.....
02-11-2023, 01:15 AM - 3 Likes   #630
Thank you
Taken with a 50mm G reverse mounted to the camera
105mm, 28mm, 55-300plm, addition, auto-takumar 35mm f/2.3, camera, club, extension, fujinon, image, k-r, kick, lba, lens, lenses, macro, pentax, pentax lens, photographs, quality, results, shot, sigma, smc takumar, takumar, tube, tubes, version, vivitar
*Macro* lens club Ash Lens Clubs 4734 4 Days Ago 07:02 AM
The Raynox Macro club audiobomber Lens Clubs 947 10-08-2022 03:12 PM
The Macro Club Christine Tham Pentax K-5 & K-5 II 18 07-08-2012 10:29 AM
What auto flash means? liukaitc Troubleshooting and Beginner Help 2 03-13-2011 08:30 PM
Macro Macro mania at the photo club MoiVous Post Your Photos! 11 04-14-2010 06:02 PM
All times are GMT -7. The time now is 04:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
