I just picked up the Tokina AT-X Pro 28-70mm f2.6-2.8 (Japanese version that just shows f2.8 on the front) 77mm Filter thread. This is the one that does not take the bayonet hood but the screw on hood.
Before I email the Ebay seller, I want to check and make sure I'm not doing something wrong with the odd focus clutch this lens has. It sounds a bit noisy (almost a grinding noise sometimes but not always) and if the camera is in single shot AF and the clutch is in the AF position, the lens won't always focus. For example, it will focus somewhat close (maybe a meter) and then if I leave the focal range alone (say leaving it at 70mm) and just focus on something distant, the focus ring turns to infinity but the actual focus does not, it's still at the 1 meter focus.
So from the reading I've done on this lens, it seems that to go to manual focus, you turn the camera to MF, then turn the focus ring to the point where the clutch will allow the focus ring to be put in the MF position. That seems to work as all the research I read.
To go back to AF, the lens focus ring will move back into the AF spot (pushing it forward) at any spot. So unlike going to MF, you don't have to find the exact spot where you were last in AF. Is that correct?
What I'm guessing is wrong with this lens is, the clutch is defective (not properly locking the lens in AF mode) or the part that actually moves the glass to focus is worn out and even though the camera motor spins the focus ring, the inner barrel that moves the lens elements isn't engaging any more. So the lens elements are not focusing.
Also, my understanding is that if the MF/AF ring on the lens is in the MF position but the camera switch is in the AF position, the lens AF is still supposed to work. The same thing happens when it's set up like this. The focus ring will turn and the lens may or may not get the correct focus. Also if both are in the MF position, I can't always get it to focus using the lens focus ring. It spins fine but particularly from about 20 feet to infinity, it may or may not focus sharply or at all.
Finally, with the lens off the body, the AF screw turns through the full range from infinity to close focus. So that works but just may not be engaging the inner focus barrel?
Last, the zoom ring is a bit tight from 35mm to 28mm. It may be that the lens was dropped even though it does not look like it.
Thoughts? Am I doing something wrong in setting the clutch?
