Originally posted by Chris Mak I am somewhat surprised, that I have not seen the (relatively recent) Zeiss 25mm f2 on this thread yet. It was never produced in ZK mount, but should be relatively easy to Leitax convert.
For me personally, 21mm is just too wide. I used the 28mm f2 for years and liked it, but it always was just not wide enough, and therefore lacking the touch of wide angle perspective that I like, just before perspective distortion takes over.
I use the Zeiss 25mm f2 on the Sony A7r with an adapter, but should I eventually go for the K1, then a Leitax mount should do fine.
The 25mm is a newer design, and has virtually no CA's and also a very lively color rendering and high resolving power, that makes it suitable as a landscape lens. If you do like the very wide angle look of the 21mm distagon, then that is still a great lens.
Chris
This discussioin on FM forums convinced me to buy the 25/2.8 insteadof the 25/2 for my type of work and I don't regret it. if i would have been a portrait photographer I would have gone for the fast version. Fast is not always better!
sculptormic wrote:
This is what i red in photozone.
Anyway I am glad I canceled my buy on ebay of this lens and bought the Pentax-A 24/2.8 instead.
Verdict
As a German website we'd love to report that we've seen another great Zeiss lens (home, sweet home after all) but at the end of the day the proof is in the pudding (or maybe in the "Kraut" here) and it just doesn't taste all that good. The Zeiss Distagon T* 25mm f/2.8 ZF performed pretty good in our Nikon APS-C review but it didn't impress during our full format lab tests. The resolution capabilities are...Show more →
This an answer I got from Tariq Gibran. Very helpfull!
The issue with tests from Photozone is that they often have little relevance for lens performance at infinity. Photozone photographs test charts to generate their MTF's and these charts are photographed at relatively close distances. So, if a lens is designed to perform best at distance and does not have say a floating element design, it's going to test poorly on a close test chart while in actual use, it could be an outstanding performer at greater shooting distances. A much better MTF measurement to go by is the one that Zeiss actually publish for all of their lenses. The Zeiss MTF's are based on infinity for general purpose lenses. If you compare the Zeiss MTF charts, you will see that the Z*25/2.8 is better outside of the center than the 25/2 as the faster 25/2 MTF shows a major dive (greater than the 25/2.8) by the time the corners approach. What the 25/2 has going for it, beyond the extra stop, is a bit more resolution in the center. It also supposedly renders beautifully. So, if you wanted a great editorial lens for say environmental portraits, the 25/2 would be an exceptional choice but if you wanted a lens that delivered better across the frame performance at longer shooting distances, than the 25/2.8 is the better choice.
Btw, the field curvature of the slower Z* 25/2.8 is at it's worst at close distances but is negligible at distance. This seems to be the opposite as compared to the Z* 25/2 and why the slower lens is better for distance.
"The 25/2.8 Distagon is wonderful all-around lens with unique close-up properties, and outstanding performance at distance. It won’t test well on by-the-numbers lab testing at close range, so ignore such nonsense and try this lens for landscape or extreme close-up use and you’ll be delighted with its brilliance and color."
diglloyd.com: Mini Review: Zeiss ZF/ZE 25mm f/2.8 Distagon
"When one starts with the wrong premises (“shoot a resolution chart at close range and that’s the measure of lens“, one naturally finds that the Zeiss 25mm ƒ/2.8 Distagon is a mediocre lens at close range on a planar target. It is why I don’t shoot resolution charts anymore— garbage in (inappropriate premises)= garbage out."
diglloyd blog: Reader Likes The Zeiss 25mm ?/2.8 Distagon After Trying It
Lloyd got this one right.
