Scratchpaddy, nice dog shots.
the 135/2.5 is very nice on FF.
The working distance is closer to me and much easier to work with w/o something/ppl getting into the frame.
Originally posted by carrrlangas @Pinholecam, you should make a video or write an article about your workflow / focusing technique with the sony A7 and adapted glass. The technical quality of the shots you posted is excelent.
I really enjoyed this thread so far. Curious to see a DFA100 shot on FF.
Thanks
I am trying not to actually (as in documenting the use of the camera)
I don't love Sony nor the way they make cameras. (technically very competent, but not too intuitive as a camera maker, to me)
So other than taking photos with my Pentax and other MF lenses on the A7, I don't feel inclined to 'push it' as a camera to Pentaxians (Sorry)
The other reality is that its really a personal choice and a $1500-$2000 one which I am not comfortable pushing the idea of this camera to ppl.
Not when it does have issues. Namely :
1. Sensor reflection
2. Adapter light leaks (depends on adapter)
3. EVF (for good and bad; some guys just can't get round it or just hate it)
4. Peaking is not as accurate as its touted to be.
5. Not as well thought out menu/options that flow well for a photographer (can be lived with, but its an irritation)
6. Not a comprehensive selection of lenses.
This is a camera that one has to make up his own mind on purchasing and hopefully be fully aware of its problems.
Ok. Disclaimers aside
On focusing with the camera, there is nothing special that I do.
Its usually on peaking level 'mid'.
If I can afford to, I use the magnification button.
If things are happening too fast, I'd just rely on the peaking to get near to the focus and then be decisive on when the subject becomes 'sharp' in the EVF.
If it looks sharp enough, its usually sharp enough.
There are actually other visual queues that can be used too.
There is a 'shimmer' sort of like 'moire' on the area that is in peak focus (watch out for that if possible)
Focus like how the camera would with CDAF, move focus fast, observe the peaking and then quickly revert the focus to get back to the point of intended focus, with the knowledge of how much 'peak' to expect.
---------- Post added 06-22-2014 at 10:24 PM ----------
Back to picts.
What do you do at the perfect sunrise location with everything setup, when a wedding couple approaches you for permission to use that same spot for their wedding photo?
Get angry?
Get in the way?
Its a once in a lifetime thing.
So I let then use the spot.
Also thought that they would actually add something to the pict
'Stole' the flash off the couple's photographer by dragging the shutter.
Pentax K24/2.8
