Originally posted by jcdoss Yeah, I'm now wondering what the T-stops are for the rest of my lenses, too. Where can one find this information, or measure it in lenses one might already have?
The best "guesstimate" i've done so far is using the known T-stop of my modern lenses.
Some website, like DxO can provide a T-stop value. DxO is not the only one. The maker of the lens can give it too (like Samyang - look the cine version that has speed express as T-stop. The 85mm if T-1,5. The 14mm is T-3,2, etc ....)
I do use the DA*55 as a base lens : it has a T-stop around 1,7 wide open (and is marketed as F1,4).
You take a picture with the DA*55 of a controled area (at the same F-stop than your other lens).
You take the same picture of the same thing, with your other lens.
The difference in exposure value, gives you a guesstimate of the t-stop.
The DA 35/2,4 has a T-stop between 2,2 and 2,4 i think.
The A 50, 1,7 has a T-stop of maybe 2,2 - 2,4.
The DA 40 has a T-Stop of 3.
the M 75-150 is around 5.
the Vivitar S1 70-210 f3,5 is probably around T-4,5 - 5.
The newer the lens, the closer the T-stop value may be to the F-stop, than the older one.
But that's just a mere guess.
